Question about Bialetti Coffee Makers & Espresso Machines
SOURCE: I have a Krup Orchestro
When you ran the cleaning cycle did you use the Krups cleaning tabs?
Posted on May 21, 2008
SOURCE: Steam stops after few seconds and water and temp lights blink
Check the 2 limit sensors on the boiler.
Posted on Jun 20, 2009
SOURCE: Krups XP2070 Stops putting water through after a
Most likely a faulty flow meter unit which is not providing the right information to the control unit. Replacing is not too difficult and the replacement meter is < $20.
Posted on Dec 29, 2009
SOURCE: Electric coffee maker no longer boils the water
As you explain i understood that heating element is in defect. Even if you don't find replacement in part DO NOT THROW IT. only remove electrical parts and you use it in direct heat , with gas or fire. buon apetit.
Posted on Aug 30, 2010
