Master
- Posted on Aug 11, 2011
Re: Red light blinks when tv is turned on., and tv...
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Please take this steps on how to determine the problem:
- Open the back cover.
- Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
- If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
- If the power supply output is normal..The problem could be on the main board...
- If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
- If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope thissolution will be helpful..
Thanks for using fixya...
