SOURCE: Replacing Control Module
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
SOURCE: Bosch she44c wash cycle time keeps extending.
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
SOURCE: Takes more than 2 hours to complete a one hour
Welcome to fixya.
**What I`m about to share applies to Almost all Electronic control B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.**
Based on your description I know what the problem is, though you may not like it.
I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line.
Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher never completes a cycle and displays "1" ( 1 is an error code for not heating ) or takes an extremely long time, is the control has detected a heating error.
Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The error likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
This is why it runs really long/forever, display`s "1" unless you "stop" it or by pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The burnt solder joint will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water.
You can also enter a test to check for proper amperage via the use of an ammeter as such...
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries.
Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
Macmarkus :)
