SOURCE: KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
SOURCE: No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
SOURCE: Our Bosch dishwasher will not turn on. It appears
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
