Question about Ovens
I have a Jenn-Air oven model S125. I think it's about an 1987 model. The stove-top and flat/griddle work great but a few months ago I notice the clock quit working and the oven no longer works. Any assistance is greatly appreciated. Thanks.
Posted by Jarred Fenner on
Gene Meier
  • 2,341 Answers
The replacement clock is no longer avaliable from Jenn Air however in my appliance repair career i run across many still in the field and have included a link for this place in Ohio that will rebuild it and send it back to you. What you would need to do or have a company come and do is remove the clock and ship it to them.Their is a curcuit in the clock that ties into the oven and its very probable that the oven not working is related to teh clock. http://www.appliancetimers.com/index.php?page=db_timer_page&Timer_id=7052&Manufacturer=Jenn-Air&Appliance=Range-Stove-Oven&Model=712024 this is their link contact them and see if they can rebuild yours. If you, or even a repair company remove it to be shipped off to rebuild, take time and make a drawing of where the wires on it go so they can be reinstalled properly once its back to you freshly rebuilt.Also be sure to insulate all the wires taken off since some will be live and if come in contact with metal without proper insulation they could short out something else.
Posted on Aug 11, 2011
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
The bottom "coil" unit in my jenn air over w132 lit up like a firecracker and burned all the way around - and now doesn't work. I replaced it about 2 years ago for the same issue. Is there something bigger...
There are no official problem notices about this so basically no. I have customers that regularly blow heating elements and coils in many other brands and quite a few go every few months.
Nov 07, 2009 | Jenn-Air Ovens
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Apr 27, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Kenmore gas stove - Top burners work but the oven doesn't
Hello Melanie!
Does the oven not heat? Are you able to program the oven at all? or is the display or read out blank?
Do you see any error codes? What youre experiencing may be control board related. If so, Fixyourboard.com can help. Feel free to respond to these questions here -- [email protected]
Best,
Megan
Jun 05, 2017 | Kenmore 30464 / 30465 / 30469 Gas Single...
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Need part number for oven bulb
looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
Feb 19, 2008 | Ovens
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you an Oven Expert? Answer questions, earn points and help others
