Question about Maytag MSD2657H Side by Side Refrigerator
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Posted on Aug 11, 2011
Jul 27, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Apr 28, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
Sep 22, 2010 | Refrigerators
Nov 01, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Aug 22, 2017 | Maytag MSD2657H Side by Side Refrigerator
359 people viewed this question
