I have a hct mytouch3G and he reconizing the SIM CARD i have full signal,but i cannot use the other aplications to set my phone.he let me use only wirelles settings.why???
It is frustrating when only your phone cannot send text messages no matter how strong the network signal is. Sometimes you feel nobody cares about or remembers you because nobody calls or texts you but actually there are. Your phone just can't be reached or can't receive text messages. When these happen, turn off the phone; remove the battery and then the SIM card. Insert the SIM card to another phone and try sending text messages; if you still cannot send text messages, remove the SIM card and let it sit off the phone for at least fifteen minutes then insert it gain. You should be able to send text messages after that, but make sure you have credits.
The next thing you should look into is the phone. Make sure network signal is present then insert a known good SIM card in your phone and try sending text messages. Reset the phone if you still cannot send text messages, but back up important files and data, such as contacts, videos, images, and messages, before doing so.
One simple way to "reset" the phone is by removing the battery and letting it sit for at least fifteen minutes. Another way is by restoring the phone settings to factory settings. Simply navigate to settings then phone settings and select "restore to full factory settings" depending on the brand and model of the phone.
This tip is not intended to solve virus or firmware problems but rather to avoid unnecessary visit to the service center and save few bucks from a problem only caused by a simple electronic glitch. Check the network signal strength and your credits before jumping into any conclusion.
its because of sim card error please insert some other sim card and on it for at least 5 hour once mobile frequency clock will set to new sim card then re insert old sim card it will take effect 100 %
Most Samsung Mobile show signal tower even if there's no network accessible. I am not very sure about this model, but you can find out, install an expired sim card and check if the network tower is showing or not, or you can just power it on without sim card and check the status of the network tower.
If you suspect the Phone, then first try your sim card on another handset/mobile and make a call using the sim card. In case it's working, then the problem is with your phone, could be settings or could be hardware or software related issue.
Reset your phone settings to it's factory default by going to the "Restore Factory" or "Master Reset" and make the changes. Try searching the Network Manually and do check the network settings very carefully. With many Samsung mobiles, there's an option that allows us to select the Network Band, so verify that there's no band selection problem. You can make the changes after you go to the Network Settings. The simplest method is to Reset the Settings to it's Factory Default.
Do you unlocked the phone?? you need figurated how to change the web settings because when u use the original sim (sim comes whit phone) you got the rigth settings to open your browser but if not, you allready delete de settings for web browser, look in the aplication if its something for change the web browser settings, or in your same phone
