SOURCE: I can't get my pics off my camera on to my PC.
Try the XP USB driver from Fuji here:
http://www2.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-m603-zoom/support
SOURCE: Can I charge the battery in Fuji FinePix J10 with my PC?
Nope. Gotta use the supplied external charger. Won't charge via USB, if that's what you are hoping.
SOURCE: how do you charge the battery on a fuji finepix z digital camera
The battery does not charge via USB.
Place the battery into the charger, then plug the charger into a wall socket.
Refer to the section titled "Charging the Battery" in the manual.
Testimonial: "Thank You, now all I have to do is purchase a charger."
SOURCE: Fuji FinePix S8000fd Digital Camera I have
Hello :
Lens error is the most common failure in digital cameras . it seems The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system . or it could have been something as small as a bump while it was being carried in your pocket or even the sand or something like it can cause this problem . Anyway the problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that manufacturers say it happened during usage. I recommend you to contact the manufacturer to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky . Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Fuji first and see what they have to say about cost of repairs. Once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
PLEASE DON'T FORGET TO RATE !
good luck
