SOURCE: 2003 yamaha wrf 250 carb problem
(1) You will need to adjust the float pin to get the correct amount of fuel in the float chamber of the carburator.
(2) You will also need to set the air-mixture screw , but before you do tht remove the spark plug and see whats the condition of it, is it black , is it brownish, or is it whitish.
If its blackish = means rich too much of fuel, if its browinsh= ok, if its whitish = its too lean.
(3) As for hesitation, check the needle at carbs piston on the accelerator cable, and blow the main jet with high pressure.
(4) Check too the spark plug gap and if its as per the manufacturers specs.
Hope this helps!
SOURCE: gas/oil mixture gushing out of airbox when throttle is opened
Please visit this site there's a lot of information on all XJs
www.xjbikes.com
SOURCE: 1987 rm 125 starts and idols fine, bogs out on take off!!!!
Pull the slide out of the throat of the carb then move the clip at the top of the needle down one notch, two if needed. This will richen the low end fuel mix.
Need a "very helpful" rating asap. Thanks!
SOURCE: Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
SOURCE: my yamaha 130hp outboard starts and runs good but
The carbs need to be cleaned.There is a high speed jet in the carb that is more than likely stopped up. Jim OMC retired mech.
