The new machine's network settings need to have the GATEWAY ip address set to the ip address of the router which will be something like 192.168.0.1 depending on the router you're using. If you can't see any networks available make sure the wireless connection isn't disabled. Look at NETWORK CONNECTIONS, wireless connection and see that it doesn't say disabled. If it is simply right click and select ENABLE.
Sometimes, the order in which u do things makes all the diffference.
1. shut down all machines
2. unplug modem and router
3. plug in just modem and wait for lights
4. plug in router and wait for all lights
5. restart computers
* if your still having an issue and your connection says local connection only then you need to reset the modem and router and then follow the above steps again.
does youre e machine have wireless connection? if not you need to purchase a wireless adapter in order for your e machine to connect to the wireless network, for the laptop you will have no problem with that because it has a built in wireless adapter, hope this help
Correct. It's looking for a standard dialer modem. You may just need to go through the internet connection wizard and define how you want to connect. With a wireless adapter, you could locate and connect to internet with that instead of a dial-up modem. Internet connetion wizard comes with Vista and XP and is found: Start > Control Panel > Network connections.
well first you have to clear this whether its a router or a modem because in modem you can't get the wireless connection.then you have to buy a wireless router.
But in case if its a wireless router then get in touch with your ISP provider to do a wireless setting on your computer as well as on your router also.
To turn wireless connection on or off for this notebook, press FN+F2 at
the same time. The wireless status indicator will turn on or off to
indicate the status of the wireless
I am pretty sure eMachine computers don't have AOSS buttons. AOSS stands for "Airstation One-touch Secure System". The button would only be on a wireless router made by Buffalo. The button is used to initiate a secure connection between it and a computer.
Try running the Microsoft updates or getting updated drivers for your wireless NIC. It's even possible that the wireless card in the laptop doesn't support WPA security. Unlikely seeing as how the board is fairly new, but possible. You might also want to try getting a PCMCIA wireless card and popping that in.
If your router is near the desktop then you are best to use a wired connection to the router using a network patch cable. If it's farther and you want to use wireless then you would need to add a wireless adapter (USB or PCI) to the desktop. These are available for about $20.
