I'm getting an "FL" message. The washer starts to fill, stops, clicks a few times, then the message appears.
FL - Failed to Lock
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
You can get it at a local appliance parts dealer near you or online and to replace it you will need to open the door, remove the screws that run though the hinges into the cabinet and the ones straight across on other side, pop the top of the front panel loose and take off, remove the screw at the top of each side and raise the top panel and swap it out; check this DIAGRAM PARTS LOCATION
Hope this helps.
