Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
SOURCE: Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
SOURCE: Parallels Desktop
Hi toy4runner,
Did you check the permissions of the folders that need to be openend by parallels to get to the file? (just select the folders one by one and for ech of them press apple - I and check the permissions section of the information pane. Chnaces are Parallels is trying to access a folder but doesn't have the right permission.
If all seems okay, check this:
http://kb.parallels.com/en/4680
Hope it helps
SOURCE: I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
SOURCE: USB Headset mM/N:A-0374A mic problem
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
?· Select and install virtualization software for your MacBook Pro. You can choose from several popular virtualization packages for the Mac, including Parallels Desktop for Mac, VirtualBox and VMware Fusion. VirtualBox is a free, open source software package, while Parallels Desktop and VMware Fusion are commercial software products
?· Install Windows within your virtualization software. You much purchase a copy of the Windows operating system if you do not already own it; it does not come with the virtualization software. Most virtualization software includes a wizard, or assistant, to guide you through the Windows installation. Windows will now run in a "virtual machine" on your MacBook Pro.
?· Install your Bernina Artista Embroidery Software on your virtual Windows system. You install software into the Windows virtual machine the same way you do on a physical PC.
?· Plug the Bernina security dongle into a USB port on your MacBook Pro. The Windows virtual machine acknowledges the dongle, and may ask you if the USB dongle is to be used with the Mac or Windows system. The dongle is a hardware device that provides copy protection for the Bernina embroidery software.
?· Run the Bernina Artista Embroidery Software by choosing it from the Windows Start menu
