Question about Vacuums
Shredder does not power on - Vacuums
Posted by nykay on
bonifacio gomez
  • Vacuums Master
  • 1,238 Answers
Good day!!!!
please try to check the plug if it is OK..
Then look for the fuse if busted...
If the fuse is busted look at the fuse if only disconnect the wire inside so that you can determine the cause of blowing of fuse..if the fuse is dark or have color black inside your machine have a short circuit..if not got fluctuate high current in split second (that is normal)..just replaced the fuse with the same type and ratings..
If the fuse always blows after power ON your machine need further repair it have short circuit..
Thanks for using fixya...
Posted on Aug 10, 2011
When I turn on the shredder and put paper through, it just keeps running. Cuts fines. Will turn off when I turn the button off. Then when I put in paper agagin, it conitnues to run.
Hi
You need to check and make sure the gap between the 2 steel rollers is correct. Because it is not grabbing the paper you need to adjust the gap by opening it.
Jul 24, 2011 | Vacuums
I purchased Shredder Model BD-S600 on 5/6/11. This was to replace another Black & Decker Shredder that I had for only a few months also. Today, when i attempted to turn shredder on to shred some...
If it's like my BD-S600 your motor is already burned out!! Same thing happened to me with this shredder after 3 months of minimal home use. I had to call them and pay $13 to send shredder back to them to have a new one sent to me, and I have already been on the phone with customer service due to problems with the new one after 5 minutes of use! Good luck to you; I know I will NEVER purchase a Black and Decker shredder again! My last shredder (a Brother) lasted 8 years with no problems and I really miss it!!
Jul 05, 2011 | Black & Decker Vacuums
I tried to shred a credit card and it will not go in reverse or forward. What tool do I use to take the cover off to remove it.
First of all, unplug the shredder. You could use either option, try the first one, first.
1) Unwind a metal paper clip and use those and tweezers to pull the shards out of the tines of the shredder.
2) The Dollar store sells a little set of screwdrivers for $1. There are some in the set that are very thin and will fit into the hole to unscrew the screws.
May 03, 2011 | Vacuums
Stops in the middle of shredding and have to reverse several times before I can complete shredding
Usually paper shredders reverse because the documents being shredded might be too thick
Feb 08, 2011 | Vacuums
Shredder will go into reverse but not forward
If this is like my elecrtical paper shredder the solution is to unplug so it cannot shred you and then take any squashed up pieces of paper out of the cutters on the inside of the machine. I have to unblock my machine after every 50 or so pieces of paper I shred.
Feb 07, 2011 | Vacuums
The Red light indicator of full box is on although the box is empty. Would not take in paper
I am a bit puzzled by the category your question is under:
VACUUMS--
I am puzzled what vacuum 'takes in paper'?--
Maybe you have a paper shredder?
Please give us some more information--- maybe we can help then.
Mack B
Jan 10, 2011 | Vacuums
I have a Braun KS32 Kitchen Machine with several attachments. Two attachments are missing instruction manual/uses: KS 32, Shredder/Slicer Attachment, and KGZ 2 Meat Grinder Attachment. Is it possible...
I have a braun machine KM32 CDN 120 Vac/3A/60h2, No. 4122912 and I was wondering if there is an attachment for a pasta maker for this machine. If there is how much is it and can I get one in Saskatoon SK Canada?
Nov 29, 2010 | Vacuums
I have a Fellowes shredder P - 35C It will work in reverse but not inwards. I have left it for considerable time but still won't start up when I insert paper.
Unplug the shredder and check the shredding blades to be sure they are not jammed with paper. If paper is stuck in the blades, it will not function to add more paper to the jam. It WILL work in reverse to remove it's jam. Also make certain the blades have not been bent by discs, credit cards, or thick amounts of paper. If all looks well, blades are straight and not clogged with paper, be sure the door (if you have this type of machine) is closed properly. If not of this helps it run, you might need to have a professional look at it OR it might be time for a new shredder.
Oct 28, 2010 | Vacuums
Paper from shredder has clogged the vacummn but I can't seem to find the area of the clog. Any suggestions? Thank you Jan
Be sure to check the hole next to the roter that might be the spot.also you can run a wire though the hose ( like a clothing hanger) do not push too hard or you will poke a hole in the hose. hope this works for ya.
Mar 12, 2010 | Dyson Vacuums
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
