Car Audio & Video Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My son is trying to install a Grundig sc 303 rescued from a scrapped car to my car. We find that when we turn the ignition key off for any length of time, we have to recode the radio. I know that when it was installed in the scrapped BMW 525 it was possible to play it even when the ignition was off, although it would switch off by default at the same time as the ignition was switched off, until you switched it back on again. Do we need to run an extra wire direct to the battery to enable the radio to retain its code?
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Car Audio & ... Master 2,226 Answers
  • Posted on Aug 11, 2011
kenw392
Level 3:
Renaissance:
Answers
2226
Questions
Helped
474333
Points
4986
The yellow wire should be going to a source that still has 12 volts when the key is turned off. This wire controls the memory of the radio.
I NEED RADIO CODE FOR GRUNDIG SC 303 D NUMBER GM1303N4258528
Any good car audio repair shop will be able to read the code for you.
1helpful
Lost code for grundig sc 303 car stereo from a vauxhall astra?
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
1helpful
2answers
Ignition locked need to replace
you are dealing with a chip in the key you may remove the cylinder but the car will not restart without programming a new switch in alanwrench
2helpful
2answers
How do i put a coil in a 2001 jaguar s type
303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual DESCRIPTION AND OPERATION Engine Ignition The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L 2001 Lincoln LS Workshop Manual
v-8
REMOVAL AND INSTALLATION Ignition Coil Removal
  1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
  1. Remove the bolts and the ignition coil cover.
  1. Disconnect the electrical connector from each ignition coil.
  1. Remove the ignition coils.
    1. Remove the bolts.
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual
  1. Remove the engine appearance cover.
  1. To access the RH bank ignition coils, remove the upper intake manifold. For additional information, refer to Section 303-01A .
  1. Disconnect the electrical connector from the ignition coils.
please rate as fixed if this helps.
3answers
The key wont turn in the ignition, I have standard car Pontiac Sunfire
Is it the orginal key? I had the same problem but found the extra key I had cut was shorter in length than the original, buyed another one and now works great
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
