Question about LeapFrog Leapster Explorer Learning Game System (green)
I gave my son a leapster explorer about a month now and it's volume just stopped working and it wont hear anything.
Posted by luby_624 on
Wale Sarumi KomputerSolution
  • 6,993 Answers
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound. . 3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
Posted on Aug 10, 2011
Leapster explorer cartridge won't fit
You have to make sure it is compatible. There are different types of Leapsters. Leapster 1 and 2, Leapster GS, Leapster Explorer and Leappad. Take it back to the store they may give you a refund or store credit.
Apr 19, 2013 | Leapster Learning System
Leapster explorer says memory full but it's not
1) Please run the LeapFrog Utility http://lfccontent.leapfrog.com/cs/utilities/LeapFrog_Connect_Utility.exe
2) Select "Clear LeapFrog Connect User Data"
3) Start the LeapFrog Connect application and wait until the message center indicates that all Leapster Explorer Updates have been downloaded.
4) Power on and plug in your Leapster Explorer.
Jul 01, 2012 | LeapFrog Leapster 2 Learning System
My leapster wont reconize the camera
I had the same exact problem. I even tried another camera with no luck. I ended up updating the firmware/software on the Leapster Explorer and the camera started working. Here is a link to the Leapster website showing you how this is done:
http://leapfrog.custhelp.com/app/answers/detail/a_id/2090/~/error-52%3A-update-software
Mar 02, 2012 | LeapFrog Leapster Explorer Camera
Hi. Our son's Leapster Explorer is good, but we are unable to connect it to the website so we can download demos and check his progress. We follow the instructions on the Cd rom and internet but it...
Try to uninstall and re-install the LeapFrog Connect. Make sure you got the latest software form Leapfrog Website instead of install it from the CD supplied from the original box.
Jun 19, 2011 | Leapster 2
My son's Leapster Explorer suddenly has no sound. If you hit the increase sound button, nothing happens. If you hit the decrease button you see the volume bar on the bottom of the page. Do you know...
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
Jun 14, 2011 | LeapFrog Leapster Explorer Learning Game...
The volume button doesn't work on our leapster explorer. It shows that the volume is at the lowest point, but it will not increase so we can hear it. We tried replacing the batteries and that didn't...
Mar 17, 2011 | LeapFrog Leapster Explorer Learning...
The sound on my sons leapster 2 has stopped
1.You can get a full refund 2.you can contact customer service 3.buy another one whith your refund:)
Oct 15, 2009 | LeapFrog Leapster 2 Learning System
LeapFrog Leapster Explorer Learning Game System (green) Logo
1,805 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
Crystal Walters
Crystal Walters
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
