SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
SOURCE: Wattage for MW8985WD microwave
I still have a orginal lable on my microwave, it is a 800 watt oven.
