Question about Casio FX-115ES Scientific Calculator
How to do matrix multiplication in scientifically calculator
Posted by manuunamf1 on
k24674
  • Casio Master
  • 8,092 Answers
Here is an account of what you can do with matrices on this scientific calculator. Certain precautions must be taken as concerns the dimensions of the matrices. Refer to your text book on matrix algebra.
On this calculator the largest matrices you can define have dimensions 3X3.
  1. First you must set Matrix calculation: Press [MODE][6:Matrix].
  2. Then by entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix (mxn].
  3. Once finished entering the matrix you clear the screen.
  4. The operations on A SINGLE matrix are available by pressing [Shift][Matrix].
  5. The choices are
  • [1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
  • [2:Data] enter values in a matrix
  • [3:MatA] access Matrix A
  • [4:MatB] access Matrix B
  • [5:MatC] access matrix C
  • [6:MatAns] access the Answer Matrix (the last matrix calculated)
  • [7:det] Calculate the determinant of a matrix already defined
  • [8:Trn] The transpose of a matrix already defined
Once you have created a square matrix, for example matA.
You press
[Shift][Matrix] [7:det] [SHIFT][MATRIX][3:MatA], close the parenthesis and press [ENTER].
If you have defined two similar matrices (same number of row and same number of columns) you can ADD them or subtract them. The operation keys are Plus and Minus as for any number.
To multiply you use the multiplication sign. The matrices must be compatible (mxn) multiplied by (nxk).
Posted on Aug 11, 2011
1 Related Answer
Anonymous
  • 108 Answers
SOURCE: please tell me to find
  1. Press the "Mode" key next to the "On" button.
  2. Press 6 to choose matrix
  3. Press 1 to Enter the matrix data in MatA
  4. It will ask for the Row by Column dimensions (mxn), press the corresponding key, for this example we'll use a 2x2 matrix, so press 5.
  5. Enter the data into the calculator using the arrow keys and number keys.
    The for now enter 1 0 as the matrix (press the = key after you have finished entering a number). 0 1
  6. Press the AC key once the matrix has been entered.
  7. Now press SHIFT, 4 and press 3 to select MatA
  8. "MatA" will now be displayed on your screen
  9. Press the "-1" key (just below the mode key)
  10. "MatA-1" should be on your screen, press the = key.
  11. The inverse of the matrix will be displayed.
Posted on Jul 02, 2011
How to multiply nxn matrix by calculatr
Put calculator in matrix mode.
Create two matrices with the same dimensions (up to 3X3).
Display the name of the 1st matrix, press the multiplication key, display the name of the 2nd matrix and press = or EXE. The result will be a matrix with the same dimensions.
Mar 02, 2014 | Casio FX991MS Scientific Calculator
How to do matrix problems in fx991ms
The following was written for the Casio FX-991 ES. If matrix calculations are available on your calculator you will perform them as described below. ( I have no time to verify that the FX-991ms can perform matrix calculations).
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matricies, at the end.)
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[4:Matb] access Matrix B
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match.
Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular umbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrice by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Nov 07, 2012 | Casio FX991MS Scientific Calculator
How to multiply the matrices using fx-991ms calculator
Nov 06, 2012 | Casio FX991MS Scientific Calculator
How to compute a matrix
  5. The choices are
You press
Aug 10, 2011 | Casio FX-115ES Scientific Calculator
How to do multiplication of two matrixes in casio fx 115es
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Apr 24, 2011 | Casio FX-115ES Scientific Calculator
Jan 09, 2011 | Casio FX-115ES Scientific Calculator
How to use the regular calculator to solve a matrix question?
  5. The choices are
You press
Sep 27, 2010 | Casio FX-115ES Scientific Calculator
How to use matrix in the calculator
Aug 06, 2010 | Casio FX-115ES Scientific Calculator
How to multiply two matricies?
Mar 06, 2010 | Casio FX-115ES Scientific Calculator
How to do matrix multiplication on Casio 115ES?
Hello
Dimensions of matrices involved in operations must match (see you textbook for the rules)
Read the appendix to your user manual, there are several exemples.
Hope helps
Sep 10, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Carlo Barzo
Carlo Barzo
paulgbrandon
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
