Question about IBM eServer xSeries 346
One drive is defunct and 1 logical drive is offline in ibm xseries 346
Posted by aamiranver on
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Posted on Nov 06, 2008
Anonymous
  • 93 Answers
SOURCE: SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Posted on May 19, 2009
Anonymous
  • 64 Answers
SOURCE: ServerRAID-6i Logical drv =1, Others=0
HI, It appears you may have a failed "physical" drive in your Raid set on the server. The system will run fine with one failed drive, but it is recommended to have the drive replaced by it's vendor, or vendor representative. If the 2nd drive in your raid set fails. You will loose your logical drive and all your data on this drive.
You may wish to confirm you have successful, recent backups, just in case another disk fails before your failed drive has been replaced.
Posted on Oct 13, 2010
Anonymous
SOURCE: I have IBM XSERIES 346
i have the exact same problem. i bought this server in an auction and i can not install any os on it. have tried ubuntu and centos but neither can find the hard drives.
Posted on Nov 18, 2010
Anonymous
  • 21 Answers
SOURCE: my IBM eserver xSeries 346 is hang suddenly ....
Try the lastest fireware. Has any new hardware been added. Run IBM diags to test all hardware.
Posted on Dec 25, 2010
Install Windows 2012 on IBM xSeries 346 server
check from the manufacturer which operating systems are compatible with your server
Mar 31, 2014 | IBM xSeries 346 Server
My IBM eserver xSeries 346 is hang suddenly ....
Dec 24, 2010 | IBM eServer xSeries 346
I have IBM XSERIES 346 server.when we start the server then a warning displaythat one logical drive is off line and two are defunt. Please help me to solw this issue.
Nov 12, 2010 | IBM eServer xSeries 346
ServerRAID-6i Logical drv =1, Others=0 Firmware7.12.13,Status OK Warning:1 Logical drive(s) Offline Warning:1 Online drive(s) defunct
Oct 13, 2010 | IBM xSeries 226 Server
Steps to configure raid10 on xseries 346 with 4 HD using raid manager cd
See page 60 of the Configuration manual for that model located at http://www.abchost.cz/download/262-4/installation-guide-serveru-ibm-xseries-346-2u-s-cpu-intel-xeon.pdf
Jan 06, 2010 | IBM xSeries 346 Server
How do I make IBM 346 server detect a scsi disk
Make sure it is connected properly and that it is displayed either in the motherboard's setup screen or in your SCSI controller setup screen.
Both of these locations can only be accessed during the computers POST which is before the operating system starts.
Once the hardware is recognized by disk controller your operating system will "see" the disk and allow you to manage it.
I hope this helps.
Jun 19, 2009 | IBM eServer xSeries 346
Hi
Apr 07, 2009 | IBM eServer xSeries 346
Physical drives not found
I"t says one logical drive is offline and two physical drives are defunct."
sounds like RAID. Try booting up off of one drive. If there is no OS, try keeping one drive in the drive bay and see if you get a orange light then. like dereknewland said, could be the backplane.
Mar 11, 2009 | IBM eServer xSeries 346
Upgrade IBM Xseries 346 Server
You can add drives to the array through the scsi management software, then you can extend any dynamic partitions that don't have the OS on them. I don't think you can extend the array if it contains the OS. You may need to use the disk management utility in windows to make the partitions 'dynamic disks' before you can extend the data partitions
Aug 21, 2008 | IBM xSeries 346 Server
Xseries 346 wont boot
Apr 02, 2008 | IBM xSeries 346 Server
IBM eServer xSeries 346 Logo
531 people viewed this question
Top IBM Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
