SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
