This button you speak of is an alternate way of depressing the shutter it is also a way in which you can use a shutter release cord to take pictures. the button itself is not meant to come out of the camera. Once you load your film or 2 empty film spools (to test to see if the camera is working properly) into the camera and wind the film crank then you will be able to depress that button and fire the shutter.
http://www.butkus.org/chinon/mamiya/mamiya_c330f_prof/mamiya_c330f_prof.htm
What does this button look like? If this button is what I think it is then with the front of the camera facing you it should be at the bottom left hand corner. The button should be chrome silver in color and upon closer inspection you should see some threading for a screw. Is this the case?
