Question about ATN American Technologies Network Aries MK238 Night Vision Scope
I have an Aries mk 208/230? night vision sight that's been sitting in the closet for several years. I put the batteries in it and it failed to work. I bought a new battery for it and it still does not work. The green power led comes on and the red ir led works but that's about it. What's your thoughts on my problem? Thanks for ;your time and effort KT
Posted by thompsonk142 on
Richard Morris
    Master:
  • 577 Answers
As you probably know that internal electronic are manufactured in Russia. I just repair an ATN MK238. Verything from the image intensifier tube to power supply was shot. I managed to round up 1 gen green Russian image tube, but the ccfl inverter, tolorid coil, voltage multiplier I had to manufactured them. Sorry, wish that I could be more help. stewbison
Posted on Aug 10, 2011
  • 1 more comment
  • LES OLSON Oct 21, 2011
    Contact this guy we buys them for salvage [email protected]
  • Richard Morris
    Richard Morris Oct 24, 2011
    Hello, Thompson., The problem will you ATN MK Series rifle scopes are the image intensifier tube. The are cheaply manufactured in Russian. I would like to get some of the Chinese Generation 2 and Generation2+ image intensifier tubes But I will have to buy 500 each. I will tell you, send the scope to me [email protected], I have a couple of new Russian tubes This scope is worth fixing and even to upgrade because of the aluminum case I will fix it for you. I wish you luck buddy. GB...stewbison
  • woodrow slone Dec 20, 2018
    I have one doing the same thing. Can anyone fix it.
Cant get illuminator tube to turn on
Hello, is the IR illuninator tube seperate from the ATN Aries rifle scope? If it is, then check the battery, ok. If the battery is ok, then check the polarity of the IR lumin. Make sure the battery is installed properly.
I hope it works, then you can take look see in the dark. Then maybe to can see some widgits. Don't mess with them, they will the smoke out, stewbison
Jun 11, 2011 | ATN Aries MK6500 Weapon Sight
Put in battery and light comes on but nothing happens, i have a aries mk 238
Jeepers! I have work on these ATN MK238 before. All internal electronic are made in Russia. There are two major problem with them. Image intensifier tube goes lights out, the ccfl inver, coil and voltage multiplier are seal in dielectric jell and epoxy. can't work of them. I can work on them, but I am not. Who ever work on it will need to install a new image tube, manufacture ccfl inverter, fine a coil and manufacture voltage multiplie and get the correct cathode ingnitor voltage, hard.
Sorry, I wish you all the luck. They one more option send it ATN and before you send it call ask what the price will be, and get the guys name or record it. stewbison
Jun 07, 2011 | AMT Datasouth Aries MK238 Weapon Sight
HAVE ARIES MK 238 BUT CAN'T SEE THREW IT,IT HAS A NEW BATTERY.
Sorry to tell you. The image intenifier tube when south with Russian timing. I have picture of the image tube but i can't figure out how to load them here. What are you going to do with the MK338. GB....stewbison
Jan 19, 2011 | ATN American Technologies Network Aries...
I would like to obtain a instruction manual for Aries MK6600 Night scope Prefer PDF Please advise
Contact custom service for ATN for a manual. I don't think they have a pdf download but you ash them. I wish you lots of luck here. GB...stewbison
Nov 06, 2010 | ATN Aries MK6600 Weapon Sight
if the eye tube is not lighting up its likley to be the censor burnd out or the tube is broken,,, dont use it in full day light,,
Nov 17, 2009 | AMT Datasouth Aries MK238 Weapon Sight
Aries 390 Paladin
Tubes can go without warning, but power supplies usually do. Get someone to check if PSU takes a current at switch on and then measure the HV.
Nov 12, 2008 | ATN Aries 390 Paladin Weapon Sight
Nite Vision scope
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayn
May 12, 2008 | ATN Aries 390 Paladin Weapon Sight
Nv sight dead
No more lights steady type: Aries 390 Paladin, light guide only focus.
Mar 27, 2007 | ATN Aries 390 Paladin Weapon Sight
ATN American Technologies Network Aries MK238 Night Vision Scope Logo
1,145 people viewed this question
Top ATN Optics Experts
john h
Tom Chichester
Bill Boyd
Are you an ATN Optic Expert? Answer questions, earn points and help others
