Question about Texas Instruments TI-86 Calculator
What is the different between ti-86 and ti-83
Posted by monar18 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
The 86 has more memory. It also has some advanced calculus capabilities the 83 doesn't. However you're much more likely to see examples for the 83 in textbooks and other references.
TI-83:
http://www.ticalc.org/basics/calculators/ti-83.html
TI-83 Plus:
http://www.ticalc.org/basics/calculators/ti-83plus.html
TI-86:
http://www.ticalc.org/basics/calculators/ti-86.html
Posted on Aug 09, 2011
1 Related Answer
  • 102366 Answers
SOURCE: Send program from one TI-86 to another TI-86
First, connect the two calculators with the unit-to-unit cable.
Prepare the receiving calculator: press 2ND [LINK] F2.
Select the item to send on the sending calculator: press 2ND [LINK] F1 F2. For each program you want to send, navigate to it using the up/down arrows and press F2. Press F1 to send.
Posted on Mar 18, 2010
I am own a Ti-nspire and trying to download the latest Ti-84 silver plus os however when it begins to transfer to my calculator it says transfer error what can i do to fix this?
The standalone version of the OS for the TI84Plus/TI84Plus SE are not for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is updated when you update the OS of the TI-Nspire. The version numbers are different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
Sep 26, 2013 | Texas Instruments TI-Nspire Graphic...
Os transferring error
Sep 26, 2013 | Texas Instruments TI-84 Plus Silver...
I bought it at a rummage sale and what a manual for it where can i get one? And is different from the TI 30X 11?
You can download the TI-30Xa guidebook from the manufacturer's web site at
http://education.ti.com/calculators/downloads/US/Guidebooks/Detail?id=6132
The TI-30Xa replaced the TI-30X within a year. The only enhancement was the added Constant key.
The TI-30XII, introduced about five years later, is a significantly different calculator, incorporating, among other things, a two-line display.
Jun 13, 2011 | Texas Instruments TI-30X Calculator
How do i do difference quotient on my ti 89?
The function avgRC( calculates forward-difference quotients and the nDeriv( calculates central-difference quotients. Take your pick. You can also use the d( differentiate function.
You can also create a small program or function that gets a function as argument, along with the variable and the step and returns one of the difference quotients. (central, forward, or backward).
Jul 19, 2010 | Texas Instruments TI-89 Calculator
How to enter a different log base (other than base e or base 10) into the Texas Instrument TI-80 silver
The TI-83 doesn't have such a function built-in. Use the relationship logb(x) = log(x)/log(b) = ln(x)/ln(b).
May 13, 2010 | Texas Instruments TI-83 Plus Calculator
Why do some TI83 program work on a TI84 plus and other don't?
Ti 83 and ti84 really have no difference and operate the same. There was something different or you had varibles used by multiple programs that conflicted w/ the ti84 and it would have done the same on the ti83. If you like to rework it and need help email me at [email protected]
Nov 20, 2008 | Texas Instruments TI-84 Plus Silver...
Different answer two different calculators ti-81 and ti89
I had the same problem when I got my first 89, even though it's really a feature and not a problem.
Press the diamond key then enter to get your answer, and it will give you the decimal answer instead of the exact answer like you have been getting. Hope this helps...
Nov 15, 2008 | Texas Instruments TI-89 Calculator
Cracked LCD display
Hello ronsky123. I sorry no parts from TI for TI-82. You may find one for sale by an indivdual or one with a different malfunction & put 1 + 2= 1. Good Luck.
Sep 14, 2008 | Texas Instruments TI-82 Calculator
Ti85
kinda. The TI-85 programs differently, lacks a table feature, is not upgradable, has redefinable keys, has a larger screen, is smaller, energy efficient, TI-86 semi-compatible, and is older.
The TI-84+ has archive memory, flash-upgradable, FSTN (clearer) screen, 16*8 screen, USB On-The-Go compliant, almost a centimeter longer, assembly language support, and a tad bit faster.
TI-82: $89
TI-83 Plus: $79-99
Free TI-85: $0
TI-84 plus: $119.99
TI-84+SE: $129-139
TI-89 Titanium: $149
Sep 06, 2008 | Texas Instruments TI-85 Calculator
SCREEN PROBLEM
Hello fezzaniaahmed. Im sorry to inform you no parts from TI for the TI-82. You may find another TI-82 with a different problem and 1+2=1. Good luck.
Jul 19, 2008 | Texas Instruments TI-82 Calculator
Texas Instruments TI-86 Calculator Logo
212 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
