Full instructions can be found in the user manual. If you need a replacement user manual go to www.maxi-cosi.com and select the model carseat you have to download a replacement.
There is a door in the back of the seat (only accessible when the seat is fully reclined). You have to open this door. You can then pull the splitter plate out from behind the seat. It is easiest to do this if you loosen the straps all of the way. Remove the straps from the splitter plate, and rethread them through the desired slots and re-attach to splitter plate. Close the door and you are done.
under the strap that is just below the grey round plastic length adjuster there is a stiched loop. Pinch the stiched loop and you will see that it can be removed.
