Question about Nokia 5250 Cell Phone
My touch screen is not working frequently. Give me the solution? How to restore my phone when touch screen is not working
Posted by musthafa_arw on
Anonymous
    Guru:
  • 586 Answers
Hello there,
If your touch screen is not working frequently, what you have to do is to calibrate the screen or check for the touch screen sensitivity. To calibrate the screen, go to the menu of the phone and select the settings, from the settings select the screen option, then you select calibrate screen and follow the rest of the instruction there on, or you select the touch screen sensitivity and increase it from there.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Aug 09, 2011
My nokia touch screen is working slow ???plz tel me how can i self solve this problem
do restore and it will help.don't forget to do your backup before doing the restore
1helpful
10answers
IPhone touch screen not working
Have you tryed reseting and restoreing the iphone?
3answers
Nokia x6 touch screen wont work
Hi even if you have seen nothing wrong with the Touch....generally this parts are sensitive,frequently short circuited the strip which is attach to the touch.Once if it is damage it could not repair.We can fix it by changing the touch.So my advise is to contact nearest mobile repairing shop.Good luck
The touch screen does not work
When the touch screen on your phone is malfunctioning,it indicates that the inner touch pad embedded with the LCD screen is bad hence the touch screen will not respond to any touch whatsoever.
However,the only solution is to disassemble the phone and replace the LCD screen of your phone to restore it back to a normal working condition.
Hope you are technically inclined,Good luck!!
Aug 14, 2010 • Cell Phones
1helpful
2answers
Touch screen not wrking..pls advice
The problem you are experiencing is due to the fact that the LCD screen of your phone is bad,hence the touch screen will fail to respond.
The solution to the problem is to replace the LCD screen of the phone,to restore your phone back to a normal working condition,if you are technically inclined and you think you can do this yourself,please let me know so i can give you a detailed stepwise guide to help you with the disassembly of your p1i,
The LCD screen costs $90.
Thanks and take care
2answers
EnV Touch VX11000 Cell Phone: I am having problems with my touch screen. It work...
once again try to calibrate if that won't work then restore your setting factory setting but before resetting it to factory setting take backup of your data
I have an HTC Touch Pro. Frequently, after I hang
If your phone isn't modified, then screen goes off - it's factory pre-set. If your phone is modified then you have to check which tweaks are applied and change settings.
1helpful
Iphone screen problems
Had this same thing happen with 2 of my apple iphones, but it was the bottom half of my touch screen that wouldn't work. Took in back to apple. They didn't even bother trying to fix the problem, said it happens all the time, and it has something to do with the touch screen not laying correctly against the plastic, so it can't read your touch. They just took my phone, and handed me a new phone each time, and at no cost, of course. I guess it's just a flaw that they had not worked out before putting them on the market. Make sure you download all your settings, phone #'s, music, and pictures by syncing it with your computer through itunes before you take it in because you will have to do a restore once you get your new phone. Also, one person told me it could be due to the plastic film you add to the screen of the iphone, if you did add a plastic screen. It can cause problems with the touch screen. I took it off of my phone, but it didn't help at all. I, also, did a complete restore on the phone, but that didn't help, either. Just take it back to apple, or send it in, and they will give you a whole new phone with no questions asked. Good luck!
Nokia 5250 Cell Phone Logo
Top Nokia Cell Phones Experts
Ekse
Resolution IT Dubai
Resolution IT Dubai
Oloyede Monsuru
