Question about Microwave Ovens
Grill will not get hot on kenwood combi 900W E how do you set it?
Posted by lenmorgan79 on
D. Floyd Kolb
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Posted on Aug 10, 2011
Can you help me to get Hinano Microwave Combi Grill manual?
I searched and did not find a website for your product. I suggest the following clarifications and also a follow up suggestion to find the manual.
1, I suggest you post the model number or part number with your request.
2. Is it Combi or Combo?
3. Is Hinano the brand and if so, do they have a website? It seems Hinano is a term referencing Tahiti and there are lots of hits for clothing and apparel but nothing for appliances.
Follow up suggestion:
If you find the manufacturer's website, go into google and type:
site:hinano.com Hinano microwave combi grill manual
That will search only that specific website (the one I hope you find to put in and not the official beer of Tahiti site listed above...) and google does a much better search than built in search engines on specific sites. Good luck!
Jan 15, 2018 | Microwave Ovens
My 24lit. LG MG-583MC multiwave microwave with grill very slow to cook i.e. A cup of cold coffee takes about 2,5 min to boiling point.
sounds like its not on high power.. Some microwaves have a popcorn button..This is usually automatically a high setting.Try putting your water in then hit popcorn...If the water heats up faster then your power settings are set wrong. You just need to change them. Your not set on high power..
Jan 12, 2018 | LG Microwave Ovens
Sanyo Microwave/Combi/Grill 900W em-g 47535 on front. Timer works but does not heat up code 1S on display. Any ideas
It hardly matters what code is showing because clearly the appliance is receiving power (timer works) and the internal workings of a microwave oven are potentially very dangerous and only competent people should open them up and fiddle around inside.
Sorry but the fact you need to ask shows you aren't a person competent enough to risk your neck inside a microwave. If it is a basic oven out of warranty it would be cheaper to replace it, if it is under warranty send it back and if it is a premium model it could be worth taking to the repair shop for a repair estimate.
Sep 23, 2016 | Sanyo Microwave Ovens
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Kenwood Combi/Microwave Oven Model K31 GSS10 User
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Unfortunately KENWOOD does not provide much online support for their products, especially their microwaves, so the instruction manual for that particualr appliance is unavailable anywhere. However, here is a direct link to the ONLINE USER'S MANUAL for a SAMSUNG microwave oven with grill that has very similar features and controls to yours which should help you out somewhat:
http://downloadcenter.samsung.com/content/UM/201011/20101126170804941/GE89ADST_XTL-03597J_EN.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this utility pre-installed.
You can always download this for free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Here also are a few links to some general instructions about using Microwave / Grill combi type ovens:
http://www.ehow.com/way_5324870_microwave-grill-instructions.html
http://www.youtube.com/watch?v=sm3wZ83JhkU
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If you were satisfied with the service provided, could you please take a moment to leave a 5 STAR rating. Your feedback is very important and I truly appreciate your consideration.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 04, 2011 | Microwave Ovens
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 08, 2009 | Emerson MW8777W Microwave Oven
Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
95 people viewed this question
Top Microwave Ovens Experts
Marvin
Marvin
acmservice
Are you a Microwave Oven Expert? Answer questions, earn points and help others
