Myob BusinessEssentials (804526027622) Logo
Posted on May 29, 2017
When I went to print an invoice it came up with"The design specified could not be found. Go to the Form Editor to select another one". I've tried to find this without success. It started when I sent a quote which I rarely do. The customer reported that the ABN number wasn't on it. I tried to check why - opened and closed things without changing anything (I think) and then tried to send an invoice instead as it always shows the ABN. Thats when the notice above showed up
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
1helpful
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Help with printing to HP Design Jet 500ps from a PDF!
I have had some success by converting pdf to jpg and printing from Adobe Photoshop. The HP 500 ps and 500plus are VERY fussy about paper size conflicts.
2answers
Hi, Is there a plug that will allow bulk printing of invoices and address labels on the same page. Or is there is a mod that can be done to the standard module to allow this. I have a running zen cart...
You can use this ONLINE tool from eBAY. ITS COMPLETELY FREE
Selling Manager is an online tool designed for medium-volume sellers to help manage and track listings on eBay. Selling Manager is conveniently located in My eBay. Use with Turbo Lister for a complete solution.
• Monitor active listings
• Generate bulk feedback and print invoices
• Print invoices and labels in bulk
Bulk Printing (Selling Manager Pro)
Selling Manager Pro subscribers can print as many as 200 invoices or shipping labels at one time from the Sold View.
To print multiple invoices and shipping labels:
  1. In the Sold View, check the box next to the listings that you want to print invoices or shipping labels for and click the Print button.
    To select all of your Sold items, check the box in the heading bar above the list of sold items
  2. From the Print page, select the printout you want, and click the Continue button.
  3. In the pop-up window that appears, use the scroll bar to preview each of the pages that will be printed.
  4. Once you are satisfied with how the pages will look, click the Print button in the browser window.
  5. If you need to edit information for a specific page, go the corresponding sales record. When you are finished updating the sales record, save your changes. Your changes will be reflected the next time you print.
This pro version is available for approx $5 per month
LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
How to do a reverse form feed in Visual Basic 6
Two things to consider:
1) The printer itself must be designed to handle reverse form feeds. I am not sure how many these days are.
2) If you're printer can handle reverse form feeds then it should be a simple matter to send the appropriate ascii code to the printer to initiate it. Much the same as if you wanted to have the printer do a line feed.
Good luck and thanks for using FixYa.
Printing problem with my invoice and estimate
MyInvoices & Estimates Deluxe
Open Company file error.
Exception: Unable to load DLL 'sqlceme35.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Printing landscape instead of portrait
this article may explain how to change it
http://hints.macworld.com/article.php?story=20070613051850612
Top Myob Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Myob Computer and Internet Expert? Answer questions, earn points and help others
