APW Wyott Zero Halliburton 100C Aluminum Case Silver with Foam Hardshell Case 100CSI Logo
Posted on Aug 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I FORGOT MY COMBINATION NUMBERS AND CANNOT OPEN MY HALLIBURTON ZERO ALLUMINIUM TRAVEL CASE. IS THERE A WAY TO OPEN IT. THANK YOU
Terry
Level 3:
  • APW Wyott Master 11,377 Answers
  • Posted on Jul 04, 2018
Terry
APW Wyott Master
Level 3:
Answers
11377
Questions
Helped
4625153
Points
152765
If it is a three digit combination, you could patiently try 0-0-0 through 9-9-9 and record each attempt until it unlocks.
https://zerohalliburton.com/lock-information
john h
Level 3:
Top Expert:
  • APW Wyott Master 29,494 Answers
john h
APW Wyott Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7557556
Points
193449
Notify manufacturer for assistance
2 Related Answers
Anonymous
  • Posted on Dec 15, 2008
SOURCE: zero halliburton triple combination lock instructions manual
Depress the square release button, just to the right of the 3 dials on outside of the case, while providing an upward pressure on the small tab on the inside of the case just behind the 3 dials. Now select your new combination by selecting new digits for each dial.
Anonymous
  • 567 Answers
  • Posted on Nov 04, 2010
SOURCE: This Zero Halliburton camera case
While it sounds overly simplistic, you might as well try "000".
This is the default code and many people don't take the time and trouble to change it. Give it a shot.
You might want to contact Zero Halliburton directly with your question.
Make sure you have some proof-of-ownership, a serial number or something of that nature.
Here's the contact info:
Zero Halliburton is a unit of Zero Manufacturing, Inc.:
500 West 200 North
North Salt Lake, Utah 84054
Tel: 801-298-5900
Toll Free: 800-500-ZERO(9376)
Fax: 801-936-2293
Email: [email protected]
If that doesn't work and the Z-H folks won't cooperate, a trip to Home Depot for a crowbar may be your best bet.
How do you reset a lock on a hot tuna case please
Picture the scene, you've just arrived at your hotel in an unfamiliar city after a long flight. You put your suitcase on the bed and slowly turn the numbered wheels of the three-digit combination lock. You press the button to get access to your case but nothing happens. The metal zipper tags remain firmly trapped in the lock's clasp...
A locked suitcase with TSA approved combination lock
Getting locked out of your luggage is something that happens to even the most seasoned travellers at some time or another. Luckily the ubiquitous, TSA approved, 3-digit combination locks used by brands such as Samsonite, Eastpack, Antler and American Tourister are easy to open without damaging either the lock or the case and without any special tools.
By following the steps described below, you will be able to quickly open the lock and re-program the code to a new 3 digit combination which is easier to remember.
A 3-digit TSA007 combination suitcase lock
How to Unlock Your Suitcase When You Forgot the Combination If you look closely at the lock from above, you will see that to one side of the 3 numbered thumb-wheels there is a small disk (see photos below).
I have found that the best way to see the disks is by using your mobile phone's camera.
Select the video camera and shine the flash down into the lock then zoom-in to see the disks more clearly.
Starting with the first thumb-wheel of the lock, turn the wheel one click at a time until you see a notch in the disk as shown in the photos.
Once you have lined up the notch of the first wheel you then repeat the process for the second and third digit until the notches of all three wheels are lined up (see the photo of the blue suitcase).
Once all three notches are lined up, turn the suitcase so you can see the numbers.
Note, this is NOT the combination code.
The notch is not visible on either disk
Write down the numbers on the first line of a blank sheet of paper.
On the next line add 1 to each digit.
Repeat this 8 more times until you have a list of 10 3-digit numbers as shown in the photo below.
Try the codes one at a time until you find the one which opens the suitcase.
Once the case is open you can change the combination for one which is easier to remember.
With practice, the entire procedure takes less than 2 minutes.
Video: How to Quickly Open Your Suitcase Lock When You Forgot the Code
When writing this article I used 2 different suitcases, both of which are fitted with TSA approved Travel Sentry combination locks. The locks are slightly different models but the procedure is identical.
I made the video using the older, blue, suitcase because the notches in the green plastic discs are easier to see than the notches in the black disks of the red suitcase.
The code which opened the red suitcase was 2 clicks away from the position with the disks lined up. The code which opened the blue case was 8 clicks away.
If none of the codes which you have written down work you should check that you lined the notches up correctly. As can be seen in the video, there are normally two positions where the notches are visible. Make sure that all 3 notches are lined up in the same position. You can see that in the video I lined up the disks at the right-hand position.
The notch on the left disk is now visible
How do Combination Locks Work?
The 3-digit combination locks used on suitcases are designed so that you can change the combination to a unique code which only you know.
To do this, you have to first set the lock to the current combination. You then press a small button (normally using a ballpoint pen) which frees the numbered thumb-wheels from the locking mechanism (currently in the open position).
You can then turn the 3 numbered thumb wheels independently to a new combination before pushing the larger button (the one which is used to open the lock). This re-connects the numbered thumb-wheels to the locking mechanism, activating the new code.
The method described above relies on the fact that part of the locking mechanism itself is visible (the notched disks next to the thumb-wheels). This makes the number shown on the knurled thumb-wheel pretty much irrelevant. Once the disks are aligned you simply need to rotate them around until the lock opens.
The notches on all three disks are lined up
What Are TSA Approved Locks?
The TSA (Transportation Security Administration) is a US federal government agency responsible for the security of travellers that was created in response to the September 11 attacks.
All luggage is scanned before being loaded into aeroplanes and if any prohibited items are detected it will be opened by airport staff and the items removed.
TSA approved locks, identified by the red diamond shaped Travel Sentry logo, can be opened using master keys. The locks are often incorporated into suitcases but TSA approved padlocks are also available.
If your suitcase can't be opened with a master key then, if they need inspect your luggage, airport staff will open it by force, cutting off padlocks etc.
To save confusion it's a good idea to note down the numbers
In theory the keys are only available to airport staff but in reality anyone with a 3D printer can print out their own master keys.
Is it Really worth Locking my TSA approved Luggage Lock? As we have seen, the 3-digit combination locks fitted to most modern suitcases offer very little or no security. At best they stop your suitcase from opening accidentally during transit, preventing your dirty laundry from spilling out on the baggage carousel.
Some suitcases (including the red suitcase in the photos) have small metal hoops incorporated into the zip-pullers allowing you to use a padlock to lock your suitcase. Although at first glance this may seem to add a second level of security, in reality, it's a waste of time. As shown in this video, zip closure suitcases can be opened quickly and easily using a ballpoint pen.
Once the lock opens you can change it to one which you can remember
Nov 08, 2018 • Cell Phones
3answers
I have the combination, but I forgot the order that it is supposed to be applied. IE do I start by turning left or right? How many times? then for the next number in the oposite direction, how many...
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
I need the turns for sentry safe 1330 i seen it on your site and i forgot to write them down can you post it again thank you
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
11helpful
3answers
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
2helpful
Forgot the code for my sentry 3110 safe
31-10-31
If this still does not open the safe, refer to the following page for additional different types of safes:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
If you need to retreive your lost combination, you can get it at this link:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
18helpful
Zero halliburton triple combination lock instructions manual
Dec 15, 2008 • Cameras
30helpful
9answers
Change luggage key combination
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Top APW Wyott Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an APW Wyott Camera Expert? Answer questions, earn points and help others
