Question about Power Acoustik LT-980/2 Car Audio Amplifier
How do i find how many ohms my amp is because i cant find it here the name of my amp is poweracustick lt 980-2 of 980 watt i want to know that so i know what speaker to hook up with
Posted by lil_chuko_13 on
jbotto
    New Friend:
  • 16 Answers
According to a listing on epinions, it appears that the amp is 8 ohms per channel standard, and can be bridged to 4ohms.
One post says that he has it bridged to 4 ohms and is getting 560 watts of output.
I couldn't find a manual for it, so you may want to contact Power Acoustik to be sure.
Posted on Aug 09, 2011
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
May 22, 2011 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
How many watts does a 59516-751 model require to run?
Answer
Simple Answer is just to know two formulas
Ohm's Law
V = IR
Power
P = IV
From those you can calculate voltage, amps, watts, ohms
V = Voltage (volts)
I = Current (amps or amperes)
R = Resistance (ohm's)
P = Power (watts)
Just solve for what you are missing.
Voltage times amps being drawn shows watts produced.
Watts divided by voltage shows amps being drawn or watts
divided by amperage shows voltage applied.
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
I would like to know how watts or rms is it
220 Watts X 2 @ 4 Ohm RMS
• 280 Watts X 2 @ 2 Ohm RMS
• 980 Watts X 1 Bridged Output
• 560 Watts X @ Mono RMS
Sep 12, 2010 | Power Acoustik LT-980/2 Car Audio...
How many watt thus a Power Acoustik LT-980/2 do?
normally check the fuse (s) example if the fuse is 40 amps the amp can do 430 rms...
Jun 24, 2010 | Power Acoustik LT-980/2 Car Audio...
How many total watts does this system have
Well... It consumes 240 watts of electrical power total so take the audio power specifications with a huge grain of salt, as no audio device puts out in audio power anywhere near what it consumes in electrical power. Heat produced is power consumed, too and nothing is 100% efficient.
In the specs below the only information useful for comparison is in the line I highlighted with >>> <<<<'s as it conforms the closest to the industry standard practice of using:
"X watts into 8 ohms (standard load) from 20 - 20000 hz plus or minus Y db at no more than .0Z% distortion"
The better amps specify vanishingly low distortion specs (0.0x% vs 0.x%) at the cost of being able to claim higher wattage. But they guarantee cleaner sound at the claimed levels.
JVC is being tricky with their choice of a 40 hz lower limit. THAT is the power hungry end of the spectrum. 20 hz is normally the lower limit stated.
"Output Power .............At Stereo operation
Front channels .............55 watts per channel, min. RMS, driven into 4 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN) 30 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN)
>>>>> 30 watts per channel, min. RMS, driven into 8 ohms, 40 Hz to 20 kHz, with no more than 0.8 % total harmonic distortion. <<<<<
At Surround operation
Front channels .............50 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Center channel .............50 watts, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Rear channel .................50 watts, min. RMS, driven into 8 ohms at 1kHz, with no more than 0.8 % total harmonic distortion."
Mar 02, 2010 | JVC RX-554V Receiver
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
Power Acoustik LT 980-2 clipping while bridged pushing 1ohm load
Hello, your problem is that your amp is rated at 4 ohms bridged mono ans 2 ohms stereo. If your running it in stereo you need to raise the ohms to 2 ohms a channel and if your running it bridged into 1 channel you need to be running it at 4 ohms. Please rate this solution please so I can prgress on FixYa.com. Thanks!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Dec 18, 2009 | Car Audio & Video
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
Lt960-4 power acoustik Amp 4 channels mono
it can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
Aug 03, 2009 | Power Acoustik LT-980/2 Car Audio...
I have a jl 1000/1 mono amp and my low ohm light was on and making a buzzing sound and found that there was a resistor that one of the terminals broke off and now no matter where i look i cant find the...
The 5 ohm could be challenging, what you could try is to get 2 10ohm 3 watt and put them in parallel. Will be 5 ohm and 10ohm is easy to get
Hope that helps
Jul 26, 2009 | Car Audio & Video
Power Acoustik LT-980/2 Car Audio Amplifier Logo
121 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
