Water Heaters Logo
Posted on Aug 08, 2011
I need a manual model no. M140T6FDN7 for a bradford white water heater? Sandi
A
Anonymous
Do you want service manual? Parts list manual? Or installation manual?
Service manual:
http://www.bradfordwhite.com/images/shared/pdfs/manuals/44943A.pdf
Other BW manuals with parts, installation, and service:
http://www.bradfordwhite.com/documentation/residential/gas.asp
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
I need a serial number for the flame sensor. I cannot locate handboodk
-Generally you have to call manufacturer with model and serial number.
http://waterheatertimer.org/Water-heater-manufacturers.html
-However, Rheem, AO Smith, and Bradford White manufacture most water heaters, and each has parts resources.
-AO and Bradford post their resources under manuals.
http://bradfordwhite.com/documentation
http://www.hotwater.com/resources/product-literature/
-While Rheem hides their parts lists on obscure link, hoping that you will call for a service recommendation.
Here is 2011 parts manual for Rheem
http://waterheatertimer.org/pdf/Rheem-Parts-Guide.pdf
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
How do you test a safety magnet on a robert shaw gas valve
Bradford White:
Bradford white service manuals:
Depending on age of water heater, The air intake may need to be cleaned.
Remove combustion parts and use compressed air to clean arrestor screen located bottom of combustion chamber.
Get more fresh air to unit.
Check gas pressure.
Check color of flame, should be clear blue and not lazy yellow.
Install new gas control valve.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
We have a bradford defender model # MI403S6FBN7. How do we reset it. lost manual
Water heaters are a huge field of knowledge. Problem is not 100% clear.
There is a resettable thermal switch on the combustion door. This switch is round and has two wires that come from gas control valve. Thermal switch trips when combustion parts have not been cleaned and they cause overheated condition, or sensor reads temperatures above 180, or thermal switch has gone bad, or gas control has gone bad.
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-8.jpg
Add a comment with more information for continued help.
1) Bradford White support:
http://www.bradfordwhite.com/supportserv.asp
2) Bradford white mi403s6fbn is 6-year-warranty 40 gallon tank-type gas water heater with Icon electronic gas valve, and atmospheric venting.
Older models have the dial-type Robert Shaw or White Rodgers gas valve.
Open following link to see age of Bradford White:
http://www.bradfordwhite.com/findaserial.asp
3) Bradford white has 'product manuals' and 'service manuals' on following link:
Product manuals have general information and advisories that people can read about water heaters.
Service manuals are for plumbers and technicians, and do-it-yourselfers for testing and repairing water heaters.
4) Typical manual for your product shows different gas valves, lighting instructions, and advisories, and troubleshoot checklist:
http://www.bradfordwhite.com/images/shared/pdfs/manuals/238-44219-00J.pdf
5) Add a comment with following information if you want specific help with servicing water heater.
What are you trying to reset on the water heater?
What are the symptoms, and what have you noticed, and what have you tried so far?
Which gas valve does your water heater have? Please open typical manual and view images of the three basic gas valves.
When was water heater last serviced and cleaned?
How old is water heater?
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
I need an upper element for my Bradford White
Go to your local hardware store, i perfer lowes or ferguson's
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
