Are you check ISO setting are these taken on? Noise is when the ISO is turned up too much. I had a look on DPreview
for you camera, but couldn't find it. Looking at this one ISO Sensitivity / Noise levels I'd say anything over ISO400 is "too much" in this case.
Could be a slow shutter speed. Try using
a hard mount of some sort. Steady your camera against something solid
like a table or a wall.
If the problem isnt solved, could be some CCD wrong; when a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hello.
Sounds like a problem with the image sensor. Try removing the battery first and the memory card, but if it is an image sensor issue, it may need replacing. Can you see the picture taken even if it is blurry? Can you still see the menu options? If you connect it to a computer and transfer the picture, are the pictures still blurry?
Can you still see the old pictures saved in your camera properly? Have you tried transferring the old and new pictures taken into a computer?
OK, I will just wait for the result.
You mean the new pictures taken are still just blurred colors when transferred to a computer? Then it is an image sensor issue. You will need to order the camera's mainboard to fix it. But that could be more expensive than buying a new digital camera.
There really is no picture of anything - just blur like clouds. I can use the Menu OK.
There were no old pictures on it. I will now try to take a picture and look at it on the computer.
No. The picture is just blurry colors.
That is correct. Just one more thing: after this problem began, there was a brief time when I could take photos, but then it started doing this again.
I assume I pay for only one consultation even though I was offered another one for pay.
I need a new camera.
Thank you.
