Cassette tape on boombox (panasonic '80/'90) won't play & when it does it eats the tape.
Hi, I remember this problem. Your " take up spindle " isn't turning. This will be the one that also fast forwards the tape, so if the fast forward doesn't work you probably have a bad rubber band that drives it, or motor for a more sophisticated model. Also this symptom could be cause by debris that has built up on the " capstan " the little silver spike that will be close to the tape heads ( also on occasion has caused tapes to be eaten-so make sure it is clean, rubbing alcohol for this-same thing for the capstan.) I hope this was useful, write back to let me know-even if it wasn't so I may try again, thanks for asking FixYa-good luck, Prodzilla
