Question about LG 19LH20 19 in. LCD HDTV
The screen has gone blank but the sound is alright.
Posted by roythatch on
Veril Gillette
    Genius:
  • 1,126 Answers
You could have a bad iverter, or a bad power supply, check and see at the input plug on the inverter is the correct voltage , and if so then if wrong, then disconnect plug and revoltage at plug from popwer supply and see if it is correct. Also check power supply module for bulged caps, elctrolytic caps.
Posted on Aug 08, 2011
SANYADE OMOTOLA
    Genius:
  • 1,622 Answers
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem.....
Just close your eyes the sun is going down you'll be alright
it's from Taylor Swift called "Safe & Sound"
TAYLOR SWIFT LYRICS
"Safe & Sound"(feat. The Civil Wars) I remember tears streaming down your face
When I said, "I'll never let you go"
When all those shadows almost killed your light
I remember you said, "Don't leave me here alone"
But all that's dead and gone and passed tonight
The sun is going down
You'll be alright
No one can hurt you now
Come morning light
You and I'll be safe and sound
Don't you dare look out your window, darling,
Everything's on fire
The war outside our door keeps raging on
Hold on to this lullaby
Even when music's gone
Gone
You'll be alright
Come morning light
Oooh, Oooh, Oooh, Oooh
La La (La La)
La La (La La)
La La (La La)
You'll be alright
Come morning light,
You and I'll be safe and sound...
Oooh, oooh, oooh, oooh oh oh. [repeat 'til fade]
Mar 01, 2014 | Apple iPad Tablets & eReaders
My Avis flat screen HD TV has sound but no picture.
First thing to try is if using a box for signal unplug both that and the set from power for several minutes and then plug back, it is possible the issue will be gone and the set working normal again.
Dec 05, 2012 | Televison & Video
The screen has gone blank!!
Charge the Walkman fully. To charge the battery of the Walkman fully keep it plugged in to the Computer for 4 hours.
Reset the Walkman by pressing the RESET button that is located at the bottom.
You can use any sharp pointed object to press the reset button.
If the issue persists then Walkman may require service.
Jul 21, 2010 | Sony NWZ-E438F Digital Media Player
BlackBerry Curve 8310 Smartphone: screen gone blank...
Sounds like you have a broken LCD. Somebody needs to open your blackberry to replace it. Go to your provider, they might do it for you. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry Bold Repair Guide that shows how.
May 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
The screen has gone blank and the sound has also now failed.
does the shop where you had it fixed give you a warranty Id talk to them sounds like a heat realted problem on the mainboard
Dec 04, 2009 | Televison & Video
Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Jul 09, 2009 | Samsung SGH-D500 Cellular Phone
LG 19LH20 19 in. LCD HDTV Logo
100 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
