Question about LG Washing Machines
Washer LG wd80264tp showing on dislay CL and not starting
Posted by hchedid on
Michael Thomas
  • LG Master
  • 3,056 Answers
Hello there and welcome to fixya
This is a very common error code this stands for child lock
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock. you may have to hold them down for a min of 3 sec and you should see it return back to normal
You can also unplug the machine for 1 hour to allow for the internal reset feature to reset the memory module ok
Hope this helps
Best regards Mike
Posted on Aug 08, 2011
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
My lg washer when pushing power on , cl starts flashing on the clock. Washer will not start.
this usually means that the child lock is activated. it is usually deactivated by pressing two buttons together, this should be mentioned in your instruction manual.
Oct 07, 2016 | LG Washing Machines
Lg wm2140cw washer error code cl My lg washer show cl and I couldn't use my washer
CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
Jul 29, 2016 | LG Washing Machines
POWER BUTTON DOES NOT WORK AND DISPLAY SHOWS "CL"
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 16, 2011 | LG Washing Machines
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
Nov 12, 2009 | LG WD-1045FH Front Load Washer
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG intello WM12235
SE error code means a communication problem between the display controls and the main control board.  You will need a qualified LG technician to locate and repair the problem.
Jun 09, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
440 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
