Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
SOURCE: How do you respool a "slipped off" drive belt on a
manuals.mtdproducts.com/mtd/GetFile.do?filename=769-02100.pdf
Posted on Apr 17, 2011
Testimonial: "Just what I needed. Info. was most helpful. Removed PTO & mower drv. belt pully & drv. belt with no problems. Will replace w/new belt. Thanks Jimmy"
SOURCE: I have a 2007 Cub
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Posted on Apr 30, 2011
Testimonial: "This was very helpful thanks pauly 46 "
SOURCE: cub cadet model LT1050, when
I believe the problem is a safety feature which is connected through the RMC, like the seat switch, just do a search for RMC on this PDF Manual it will show you how to check and what does what, Hope it helps and Good Luck Tim:
http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02100.pdf
Posted on May 21, 2011
SOURCE: wiring schematics for 2007 cub cadet lt1045 need
this should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 04, 2011
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Apr 18, 2014 | Cub Cadet Garden
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Dec 13, 2011 | Cub Cadet Garden
Jun 04, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Apr 30, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
163 people viewed this question
