The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Testimonial: "Cheers mate, spot on, freezer working a treat with no leaks...yeah"
Hi, thanks for your response. When you refer to the drain do you mean the white / clear pipe which comes out from the underside of the freezer and discharges into a white plastic tray? (I have removed the lower black panel cover from the backside of the fridge / freezer). Do I defrost the drain pipe from the outside or inside (i.e. point the heat towards the lower backside of the freezer section). I also noticed the the 'thick' wire loop (Part Number 0628) was flowing orange / red (looked very hot), is this normal?
