Question about Keurig Elite B40 Coffee Maker
Yesterday morning my maker worked just fine, but this morning it will not power on. Need my coffee.
Posted by revwdm on
D. Floyd Kolb
  • Keurig Master
  • 43,501 Answers
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 04, 2011
Keurig B60 lost power purchased Nov..2010
Because the debris has now clogged the exit port and needs cleaning with a paperclip end. pg. 18 Manual.
Jul 27, 2012 | Keurig B60 Coffee Maker
I pressed the button to turn on my Keurig this morning and it did not turn on. What might the problem be? It worked fine yesterday.
heatman101
Aug 25, 2011 | Keurig B60 Coffee Maker
I have a Bunn coffee maker (Model NHB code date154704) that trips the ground fault breaker the second you plug it in. It worked fine yesterday, but last night my wife put half water and half vinegar in it...
The water doesn't come into direct contact with the heating element. The only way to know the cause of the problem is to use a multimeter and test the circuitry.
Sep 28, 2009 | Bunn RL Coffee Maker
Coffee maker is about 2.5 years old. Has worked fine until...
does it have two switches? mine does and if the main is off, the other is off.
Sep 18, 2009 | Cuisinart DCC-2000
Will not turn on
Hi, What brand coffee maker? bobbyone
Aug 27, 2009 | Coffee Makers & Espresso Machines
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Bunn coffee maker not working
My warm indicator light is not working. Only used less than a month.
Nov 15, 2007 | Bunn NHB Coffee Maker
Keurig Elite B40 Coffee Maker Logo
79 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Vincent G
Vincent G
Colin Stickland
Colin Stickland
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
