Question about Kodak EasyShare V1003 Digital Camera
Delayed focus I have a Samsung Digimax that takes good pictures except that after each shot it has about a 2 second focus delay. When I then try to upload these images onto my desktop it pulls them all up as a blurry image. How can I adjust my settings so that they have a chance to focus before loading?? Thanks for any advice you can offer.
Posted by stephie64 on
4 Related Answers
Anonymous
  • 1027 Answers
SOURCE: picture delay
The cycle speed is fixed internally, and is caused by the record time to the memory card.If possible, try a faster rated memory card - some are advertised as being 100x!
Posted on Apr 18, 2009
Ty Price
  • 11967 Answers
SOURCE: When I hit the take picture button, there is a
It's called "shutter lag". To overcome it press the shutter half-way and lock in the focus before pressing the rest of the way.
Posted on Dec 18, 2009
  • 102366 Answers
SOURCE: How do I shorten the shutter speed.
Shutter lag is one (of the many) problems with compact point&shoot cameras, not seen in bulkier (costlier, more complicated) dSLRs. You can reduce the lag by pressing the shutter release button halfway to focus and meter beforehand. Keep the button half-pressed while anticipating the key moment, then press the button the rest of the way.
You'll have to release the button and half-press it again if the distance to the subject changes, or it moves to/from light/shadow.
Posted on May 13, 2010
Anonymous
  • 14 Answers
SOURCE: Why does my camera delay
Are you still using the same card? You might have changed the card with different speed.
Posted on May 20, 2010
Why does my canon power shot hesitate before taking a picture
It's probably acting normal. Every camera (in one of the auto modes) must focus before it takes the image. In low light situations, or low contrast situations (white dog against a white background), many cameras have difficulty finding focus. This causes a delay before the shutter clicks. Try taking your camera out on a nice sunny day and take a pic. If there's no delay, there's your answer. If in a low light situation, click your flash on. That may help a bit to reduce the delay.
Jul 02, 2014 | Cameras
Canon 60D
If the problem is exposure delay (2 seconds delay timer) check drive mode setting, set to single shot.
Jul 22, 2013 | Cameras
There is a delay between pressing button and photo being taken with my samsung s7000. The delay means that the subject (child) is out of view by the time the photo is taken.
Hi Susan, and welcome to FixYa-
I have had the exact problem that you are describing, albeit a different make and model of camera. Here's how I solved my issue:
I grabbed the nearest heavy object and smashed the camera....
No, but seriously, try this:
The S700 has the standard "Scene Selector" knob on the top. Make sure that this is NOT pointed toward (set to) the "Self Timer" option. The icon for this, on the camera's body, looks similar to the "Auto" setting icon.
The S700 has 3 timer modes: a 10 second delay, 2 second delay and a "Double" mode wherein the camera waits 10 seconds, takes one picture then, after an additional 2 second delay, will take a second picture. The delay must be selected by the user and will appear in your LCD viewing screen. Prior to taking a test picture, look in the display screen to see if any numbers appear. If you see any, you know that the camera is in the Self Timer mode. Simply rotate the button on top of the camera to the "Auto" icon and you'll be all set.
Good luck, and let us know how you go!
Aug 10, 2011 | Samsung Digimax S700 Digital Camera
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
When i push the button to take a picture, the camera delays for about 3 or 4 seconds before it actually take the pic. Why does it delay?
There could be several problems like:
1)The focus.
2)Self timer set to 2sec or 10sec.
3)very slow shutter speed set.
Make it as a 10 or 20 second delay on the self timer .Your problem here could be that the settings are not right. Go to the menus and reset all to original or default. Then set menus the way you like. You may have a slow memory card, try changing to a faster card, and test it.
Thank you!
Jun 19, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
How do I delay a camera shot on the fujifilm finepix j12? I would be extremely grateful anyone knows how to do this, to write me a solution, thanks :)
The self timer mode is set with the down button on the Menu/OK dial.
It looks like a clock set at 10 to 10.
The first press sets it to delay 10 seconds, the second press sets it to delay 2 seconds and the final press turns it off.
To take the picture half press the shutter button to focus then press it all the way to start the timer.
Hope this helps.
Mar 08, 2010 | Cameras
Timer?
hi... try this method
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
tripod).
The camera takes the picture/pictures after the delay....
thank u
May 24, 2009 | Polaroid i830 Digital Camera
Very long lag time to shoot and between shots... sometimes!
hello again after researching i did find out that there is about a 3 second delay if using the flash option did any of your delays happen when not using the flash ? also does this happen when using the camera in auto mode ? turning the knob on the top to the green auto mode i'm thinking it also could have to do with your shutter speed or try going to the menu and changing the shutter speed to a faster speed your self then taking pictures in av or tv mode. here's a comment from a review on the PowerShot a590 that might help. Camera performance is very good. The PowerShot A590 is ready to shoot after a 1.2 second delay -- pretty snappy. Focus speeds were very good, even in low light situations. Shutter lag wasn't a problem, and shot-to-shot delays were minimal, except when you're using the flash, which is slow to charge. The camera can shoot continuously at 1.5 frames/second until your (high speed) memory card is full. The A590's battery life is 10% better than its predecessors, and is well above average for its class. The camera supports the USB 2.0 High Speed standard, for fast data transfer to a Mac or PC.
and if you still have the problem with out the flash then the only other solution is a faster flash memory card there's cards made just for digital camera's that store pictures and format quicker.
hope this helps your enjoy your camera.
Apr 04, 2009 | Canon PowerShot A590 IS Digital Camera
Taking a photo of the family, delaying the camera until I can get into the shot.
Sure, follow these steps...
  • Set everyone in an even composition, close together, maybe some standing, some sitting, whatever strikes you as a good picture.
  • Put the camera on a tripod or other tall article
  • Press the Mountain/Macro/Timer button until the (clock/timer) icon is displayed on the viewer. The button to press is just above the MF (Manual Focus letters)
  • Press the shutter button all the way down to activate the timer.
    • Press once for ten-second delay
    • Press twice for three-second delay
    • Press a third time to stop the timer
  • Jump into the shot! =)
The lamp next to the lens will start to blink and continue until one second before the picture is taken. The lamp will then stay solid during the last second to warn about the picture being taken.
Please rate FixYa!, ThankYa!
Dec 15, 2007 | Nikon Coolpix 4500 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
