Question about Dictaphone 3750 Desktop Cassette Transcriber / Recorder
Dictaphone transcriber 3750 won't play, reverse or go forward. Foot pedal will not control the tape as well. Says end of tape on machine but its not the end of the tape
Posted by bbailey377 on
2 Related Answers
Anonymous
  • 6 Answers
SOURCE: Dictaphone 3750 transcriber
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
Posted on Oct 30, 2008
3vil3lvis
  • 43 Answers
SOURCE: Dictaphone transcriber 3750 won't play, reverse,
Does anything show up on the display? Like 'No Cassette' or 'End Tape'?
Are you using a foot control? Does the tape move when pressing the buttons on the machine itself? Is the foot control plugged into the side of the machine (and NOT the back)?
Posted on Jun 07, 2010
When using the foot pedal for forward playback to transcribe, when you lift your foot to stop the tape continues forward for about a second.
It sounds to me that you might have a mechanical problem in the machine. I am not familiar with this machine, but I have worked on lots of tape machines. The belts and rubber pieces can get slick or stretched causing problems.
Oct 24, 2017 | Sony M-2000 Microcassette Transcriber
Machine will re-wind but will not play or advance -- well it does a little and then the 'end of tape or no cassette' bar shows up on the display. What's wrong?
Hello Your unit needs to be send for service to be fix you can try to Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem they will service your unit
Jun 02, 2010 | Dictaphone 3750 Desktop Cassette...
Foot pedal does not work for my Dictaphone model 2750 Where can I purchase a replacement
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Apr 30, 2010 | Dictaphone 2750 Desktop Cassette...
Dictaphone transcriber 3750 won't play, reverse, or go forward. What can I do?
Feb 18, 2010 | Dictaphone 3750 Desktop Cassette...
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Sep 09, 2008 | Dictaphone 3750 Desktop Cassette...
Dictaphone 3750 Desktop Cassette Transcriber / Recorder Logo
106 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
