Televison & Video Logo
I failed to do an auto or manual search for new channels provided by cable companies. my television is Hitachi cle-957.
Posted by gka0 on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
CHECK IF IT IS IN HOTEL MODE, PLEASE TURN OFF THE HOTEL MODE&TRY AGAIN.
Posted on Aug 08, 2011
2helpful
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
1helpful
Manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
1helpful
No access to channels over 37 (Not a cable provider problem)
try to autotune manually there should be a menu button on tv hit thta then go to channels then hit auto program..make sure u have cable selected as the input not air/antenna
Auto Search for Local channels not responding
Hi elmergdavis,
Check and make sure your tv is set to CABLE and not to AIR or ANTENNA. This setting is usually just above the Auto Search utility on the meNU.
Let me know what you find and I can provide further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Only receives 13 channels
try unpluging the set for a few minutes then re-do the auto search if that does'nt help upgade the software.call hitachi for this upgrade.
Tuning
Same here. I have the tv with a hitachi r/c CLE-87613 but can't tune the tv to the aerial channels.
My email is [email protected]
2answers
No recption pass channel 12
judging by the year, this set should definitely be cable ready. check the front of the tv if it has a control panel for a switch that says catv/normal or something similar, if it does not have that switch, check the settings via the remote.
the channel a connector may require an adapter depending on the type of connector. i had an old tv that required an adapter in order to plug the cable coax into it, it resembled an rca connector and is used on some older tv's in place of a screw on connector.
if all else fails, your cable company should be able to provide you with a tuner/converter for free or minimal charge.
i hope this helps,
trin
1helpful
Hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
Setup for coby tv-dvd 1350
I need to download the instruction/manual. Can someone direct me?
Thanks
Top Televison & Video Experts
Marvin
Marvin
