Heating & Cooling Logo
Question about Haier HWR24VC3 24,000 24000 BTU Air Conditioner H-W-R-24-V-C-3, H-W-R-24VC3, HWR24-V-C-3, H-WR24VC...
Displays "E1" and resetting the
Posted by dukehaterhee on
Robert Moller
    Guru:
  • 1,524 Answers
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Posted on Aug 08, 2011
2answers
Breezaire WKL 1060. System was working but had iced up. Then followed instructions to clean up and restarted. It runs for a short period of time then shuts off with an E1 error code.
ON A WKL 1060 AND FOR THAT MATTER ON ALL WKL UNITS THE E1 CODE IS NOT AN ERROR CODE ITS A FEATURE.
ON INITIAL START UP OR AFTER UNPLUGGING THE UNIT FOR MORE THAN 10 MINUTES (RESETING THE BOARD) THE UNIT WILL RUN FOR 30 MINUTES AND THEN IT WILL CHECK TEMPERATURE INSIDE THE WINE ROOM, IF THE TEMPERATURE IS 70 DEGREES OR ABOVE IT WILL DISPLAY E1 AND SHUT OFF THE UNIT. YOU WILL HAVE TO RESET THE UNIT BY UNPLUGGING IT FOR NO LESS THAN 10 MINUTES TO RESTART THE UNIT, IT WILL RUN FOR ANOTHER CYCLE OF 30 MINUTES AND IT WILL RE CHECK TEMPERATURE AGAIN, IT HAS TO READ 69 OR LOWER FOR THE UNNIT TO RUN NON STOP TILL IT MEETS THE SET COOL POINT OF 55 DEGREES.
10helpful
3answers
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
After running self clean the display shows E1 and F5 and the door will not unlock. How do I unlock the door and reset the display?
The only real thing you can try is to unplug the unit or turn breaker off for about 30mins too see if it resets the board. The E1 F5 is a door lock error so hopefully pulling power from it awhile will work.
E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
6helpful
2answers
How can I clear E1 permently from my AC
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
1helpful
2answers
3answers
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Top Haier Heating & Cooling Experts
Tom Chichester
Akbar Mughal
Akbar Mughal
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
