Question about Health & Beauty
Can passive and active transport occur in dead cell?Explain
Posted by domingorenzl on
kelvin rios
    New Friend:
  • 3 Answers
The definitive answer is: it depends. It depends on how the cell "died". Most forms of cell death include getting holes in the membrane, and if that happens any type of transport (active or passive) is pretty much impossible. The transport proteins might still be working, but whatever they're moving across the membrane would just leak back through the holes, so there's no transport. If there aren't holes in the membrane, then passive transport should still work. For active transport, it depends again. Usually for active transport you just need the transporter and an energy source (like ATP). As long as the energy source is still around, active transport will still go on. Chances are, though, that the dead cell isn't making more ATP as the old is used up, so pretty soon it will run out and active transport will stop. Other forms of active transport don't use ATP directly, but they still count on the cell using energy. When the cell dies, those transporters will also stop working before long.
Posted on Aug 08, 2011
Subwoofer 500 watt bass wont work
What is wrong? totally dead? If passive unit check for a blown speaker surround, if active unit check for a bad Power supply or bad amp.
Sep 03, 2017 | Car Audio & Video
Why is our zsf6128 dishwasher is stuck in dry mode and cannot start it
I'll try to explain how drying works generally in the dishwasher.
Dishes absorbs heat and cools more slowly than a very thin wall of stainless steel.
The consequence is that water evaporates and in accordance with the Mollier diagram begins to condense on the walls of the stainless steel whose temperature is lower due to faster cooling of the dishes.
Now drying can be divided into two categories. Active and passive.
Passive way of drying the natural circulation of moist air and condensation in the condenser, which is usually located on the left or right side of the dishwasher.
Active way of drying works on the principle of forced circulation humid air with fun helping quickly condenses and thus speeds up the drying of dishes.
In passive mode the drying process can speed up the partial opening of the door.
Dado
Sep 22, 2014 | Zanussi Dishwashers
Dx 302 wont dry dishes
The model you specified is unknown to me and I'll try to explain how drying works generally in the dishwasher.
Dado
Aug 08, 2014 | Electrolux Dishwashers
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
How do I hook up passive subs to my board
Sub outs needs an active speaker.
An active speaker have a built in amplifier and preamplifier.
For a passive speaker it needs an amplifier.
Oct 01, 2012 | Mackie 2404-VLZ3 Mixer
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Is denon 1356 with active bass. and i want to know the difference between active bass and passive bass.
Hi....
A passive bass is a box with a sub-woofer in it.
An active bass is a box like that with an amplifier built in.
Hope that helps.
Check the Denon site too
Dec 26, 2008 | Denon AVR-1803 Receiver
Health & Beauty Logo
287 people viewed this question
Top Health & Beauty Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
