NRS Bilz Box Logo
A
Anonymous Posted on Aug 08, 2011
Do not have set-up instructions for Bilz Box can you please email the instructions?
Solution to bilz box
bilz box ,what make of car is this please
2answers
Can I configure microsoft outlook 2007 to work with my yahoo e-mail if i'm connection through clearwire at home and I'm not on a network
If you are not connected to the internet, you can only work offline, and for example, if you write an email it will not send until you do connect to the internet.
You can configure Outlook 2007 to work with Yahoo.
If you want to "POP" your Yahoo! Mail into your Outlook 2007 application, here's how:
  1. From the Tools menu, select "Account Settings." If you do not see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the Email tab, click New.
  3. Check the box next to the first option, "Microsoft Exchange, POP3, IMAP, or HTTP" and click Next.
  4. In the Your Name box, type your name as you'd like it to appear when you send a message.
  5. In the Email Address box, enter your Yahoo! Mail address (for example, "[email protected]").
  6. Check the box for "Manually configure server settings or additional server types" and click Next.
  7. Check the box next to the first option "Internet E-mail" and click Next.
  8. In the Server Information area, under "Account Type" select POP 3 from the pull-down menu.
  9. In the Incoming mail server field, enter: pop.mail.yahoo.com.sg
  10. In the Outgoing mail server (SMTP) field, enter: smtp.mail.yahoo.com.sg
  11. In the Login Information area, in the User Name field, enter your Yahoo! ID (your email address without the "@yahoo.com").
  12. In the Password box, enter your Yahoo! Mail password.
  13. Check "Remember Password" if you don't want Outlook to prompt you for your password each time you check your mail. Handy!
  14. Do not check the box labeled "Log on using Secure Password Authentication (SPA)."
  15. Click on the More Settings button.
  16. Click on the Outgoing Server tab and check the box next to "My outgoing server (SMTP) requires authentication."
  17. Click on the Advanced tab.
  18. Under "Incoming Server (POP3)", check the box next to "This server requires an encrypted connection (SSL)". The port number in the "Incoming Server (POP3)" field should automatically change from 110 to 995. If it doesn't, make sure the port number is set to 995.
  19. Under "Outgoing Server (SMTP)", check the box next to "This server requires an encrypted connection (SSL)". Enter port number "465" in the "Outgoing Server (SMTP)" field.
  20. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, don't check the box.
  21. Click the OK button.
  22. Click the Next button on the Email Account Wizard, then click Finished.
  23. Would you like your Yahoo! Mail inbox to be your primary inbox in Outlook 7? If so, click the Tools menu and select "Account Settings." If you don't see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  24. From the list, select the pop.yahoo account you've just added and click the Set as Default button.
  25. Click the Close button. You're done!
Troubleshooting instructions
If you followed the above configuration steps, you should be all set. However, if you cannot send or receive mail with your email client, try the following tips.
The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on, follow these steps:
  1. From the Tools menu, choose "Account Settings."
  2. Select the "E-mail" tab.
  3. Select your Yahoo! Mail account and click Change.
  4. Click on the "Outgoing Server" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Please make sure that "Log on using" is not checked.
  7. Click OK.
To control deletion of messages from the Yahoo! Mail server:
  2. Click on the "Email" tab.
  4. Click on the "Advanced" tab.
  5. Check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Please note that setting your email client to remove messages from the server will cause your messages to be deleted from the server. Once the messages are deleted, we are unable to retrieve them.
  6. Click OK.
  7. Close Microsoft Outlook and restart.
We strongly recommend that you enable SSL for both POP and SMTP, as detailed in the above instructions. This will ensure that your Yahoo! ID, password and email messages are transmitted securely between your mail client and the Yahoo! servers. However, if you choose to not use SSL for SMTP, your email client will likely default the SMTP port to 25. If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
  1. From the "Tools" menu, select "Account Settings"
  2. Select your Yahoo! POP account and click on Change.
  3. Click on the "Advanced" tab.
  4. Click OK and Close.
1helpful
Need router lettering template set instructions 70709
I recently purchased craftsman lettering tempate set 70709 at an auction. The operating instructions are in the box. I can scan and email to you. Only 2 pages.
But I need your email address to do this.mine is [email protected]
Dec 01, 2010 • Garden
How do i reset facebook.
Instructions
  1. change-facebook-email-address-1.1-120x120.jpg Log in to your facebook account and look for the "account" button. This button will be found at the upper right hand of the page.
  2. 2 change-facebook-email-address-1.2-120x120.jpg And under the "account" button, simply drop down the arrow and click on "Account settings" button.
  3. 3 change-facebook-email-address-1.3-120x120.jpg When you are in a new page or "account settings" page, you can see this word "email" next to a "username" text within the page, simply click the word "change" located in front of the "email" text.
  4. 4 change-facebook-email-address-1.4-120x120.jpg After clicking the word "change" you will be brought to a new page. In a new page you can see a textbox for "new email," below the "contact email" text. Simply type the new e-email address that you want to use.
  5. 5 Please take note that the "new e-email address" is referring to a new e-mail address that you want to replace to your old or current email address.
  6. 6 change-facebook-email-address-1.6-120x120.jpg When you are done inputting the new email address in the text box simply click the "Add new Email" button below the box. That's it! Very easy! please comment on the post
6helpful
Want to sign in to my yahoo mail box
Go to mail.yahoo.com and enter your username and password. If you've forgotten them, click on "I can't access my account."
If you need instructions for how to set up your email program (like Outlook Express) to check your Yahoo account, write me back and I can send you those.
Good luck! If this helps, please leave a rating!
Mar 13, 2010 • Yahoo Mail
Dea .sirs I cannot get my pop settings to work and cannot send e mail please assist thank you jeremy silwood
Please follow the settings below:
* Click on Tools> Account Settings.
* Under the Account Settings window, click on the Email Tab, click New.
* Select Microsoft Exchange, POP, IMAP, or HTTP > click Next.
* Under the Auto Account Setup, place a check in the box called Manually Configure
Server settings or additional types, click Next.
* Select Internet Email, click Next.
Next, fill out the following information:
* User Information
Your Name: Your Name (e.g., Joe Black)
Email Address: username@email (e.g., [email protected])
* Server Information
Account Type: POP3 or IMAP
Incoming Mail Server: pop3.yahoo.com or imap.yahoo.com
Outgoing Mail Server: smtp.yahoo.com
* Logon Information
User Name: username@ (e.g., [email protected] - This must be your full email
address)
Password: password
Check the box remember password if you would like the system to remember your
password. Please note: requiring your password to be entered each time you open
Outlook will ensure your email is better protected and will prevent others from
accessing your email without your consent.
* On Outgoing Server tab, check the box My outgoing server (SMTP) requires
authentication and confirm that the radio button Use the same settings as my
incoming mail serveris selected.
* On the Advanced tab, choose the following settings:
Incoming server (POP3) > Place a checkmark in the box next to This server requires
or
Incoming server (IMAP) > Place a checkmark in the box next to This server requires
Outgoing server (SMTP)
Enter port number: 25, 2525 or 465
Use the following type of encrypted connection: Auto
* (For POP3accounts only) On Advanced tab, under Delivery, adjust the settings to
meet your requirements.
Click OK. Finally click Next, and then click Finish.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Feb 13, 2010 • Yahoo Mail
3helpful
Little tikes crazy coupe
Here are the instructions on how to assemble the Cozy Coupe. Hope this helps!
http://www.littletikes.com/pdf/4855CozyCoupe.pdf
Blessings,
The Grand Toy Wizard
http://www.thegrandtoywizard.com/store
Cable hook-ups for TV, Satellite Box, DVD, VCR
Use SCART lead from Sat. box to VCR input( so you can record progs.) then another SCART lead from VCR output to TV set AV1 input. Connect DVD (player only I presume) direct to AV2 input of TV set using another SCART lead.
Hope all this works O.K.
Note:- If DVD is also a recorder then you don't need VCR as a recording device and leads will need to be altered accordingly, of course!!
2helpful
2answers
Lost instructions need help!!
HI, I am looking for the instructions for the conversion kit for this crib. Unfortunatley, the kit sat in the box, unopened for 2 years & now it is discontinued. There were no directions included in my box, please help!
Top NRS Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a NRS Toy Expert? Answer questions, earn points and help others
