Question about Refrigerators
I have a Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GR that seems to have a defrosting problem. I submitted a question and after looking at the freezer the inside coils were frozen . The inside fan was working and so was the bottom fan on the outide. What can I look at to correct the defrosting problem? I don't see how the fan would direct the air across the coils to keep them from freezing? Thank you
    New Friend:
  • 3 Answers
In the freezer compartment, there is a heater tube that stops the freezer from freezing up. It is probably blown, and you need a replacement heater tube.
Posted on Aug 08, 2011
6ya staff
SOURCE:
I cant find the filter on my hotpoint no frost refridg.number csx22gr where is it.
your model number doesn't come up.if it's an older machine some didn't come with water filters,you had to add an inline filter on the copper water line,you would run your copper,go down the cellar or behind the machine,cut the copper and the filter connects in between the copper where you cut the line.if you do have a filter it could be in the fridge section top right side or down in the bottom kickplate.i found your model the a was missing after the b baww.it doesn't show a filter,this is an older unit,check behind or in basement,wherever the water line goes and see if there's a filter added into it,if not you can cut the copper and add a filter yourself.home depot sells them
http://www.homedepot.com/p/Whirlpool-In-Line-Refrigerator-Water-Filter-4378411RB/202204720#.Ug7jNxXD_X4
Aug 16, 2013 | Hotpoint 21.7 cu. ft. Side-by-Side...
Where is the defrost ti mer for a hotpoint side by side refrigeater
hi.without going into minute detail most defrost timers r behind bottom plinth or inside refrigerator control panel cover if it is a mechanical timer,otherwise PCB.GOOD LUCK.
Jun 18, 2012 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Need to replace the water filter on my hotpoint no frost csx22re side by side. where does it located and where can i purchase a filter?
This filter is on the top right back inside of refrigerator, turn counter clockwise to remove. You can purchase the new ones at lows, home depot or order online.
May 29, 2011 | Hotpoint 21.7 cu. ft. Side-by-Side...
We have a hotpoint refrigerator. The Frezer seems
There is a part called a defrost timer, it is usually the most likely culprit in these situations. Hope this helps
Oct 07, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refrigerator freezer not cold
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Is there anything else that makes you think this is a problem.
Sep 11, 2009 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
It just quit after a couple of months of very little use.
Most likely you have a defrost problem. When you unplug it for a couple of days, it thaws out and you plug it back in and it works until it freezes up again. Possible problem ...1 of 3...defrost timer...2 of 3...defrost heater...3 of 3...defrost bi-metal.
Apr 01, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Bad odor comin from rear of refrigerator
the drip pan have to be clean pull the pan out and clean
Jan 05, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Apr 24, 2007 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
