Question about Zenith IQB64W10W 64" Rear Projection Television
I hit the power button and it warms up with no picture, no sound then it powers off
5 Suggested Answers
6ya staff
SOURCE:
Lashawn Robinson
  • 1153 Answers
SOURCE: Hitachi Model# 50UX19K
You will need to look in back and see what led's light up and this tells what is wrong with set
Posted on Dec 09, 2007
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Posted on Aug 01, 2008
jan mczeal
Jan McZeal
  • 632 Answers
SOURCE: My Sony 51 Inch when I hit the power the standby
You need to change the projection lamp. Use XL-2400 replacement lamp..for information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Putthe new lamp in its place.
  5. Mount it securely and take extra care not totouch glass portion of the lamp..Use gloves as a precautionary measure.
  6. Turn the knob back to CLOSE and secure the cover.
  7. Put the outside lamp cover back in its place.
  8. Turn on the TV and browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Dispose the used lamp properly..it contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Posted on Aug 14, 2009
SOURCE: TV turns on sometimes
Maybe they got an electhrolitic capacitor near the horizontal side of the tv maybe about 250 volt to 1 mf or more
Posted on Apr 12, 2010
I have a Toshiba 47hl167 and when I plug it in and hit the power button the green light comes on but no picture?
The real issue is do you have sound or not?
You can unplug the set and or a box both if connected for several minutes and then power back to see if when they reboot set works or not.
Dec 10, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Insignia tv no picture and sound until it warms up
it only takes one bad or slightly bad cap to cause this, back a bit, caps that have a problem will begin to regain some capacitance after they get hot------does this sound familiar?
just id the cap and replace it and look for any others even slightly puffy.
Sep 02, 2012 | Insignia IS-LCDTV32 32 in. Television
Apr 12, 2010 | Zenith B27A11Z 27" TV
Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Jan 18, 2010 | Sanyo DP19648 19 in. LCD TV
Power light comes on for 2 seconds and then off.
Need to have the power supply rebuilt, expect to pay around $350 Julio at [email protected]
Jul 21, 2009 | Mitsubishi WS-55807 TV
Same thing happened to me
Well, no sound no picture = power supply unit
Sound no picture= flyback
picture no sound =tuner/audio logic
You get my drift?
You power supply is bad you replace it you got another new TV, with this digital conversion hitting I would rather advise you to get a nice flat panel and donate that one to Goodwill
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | RCA F32650 32" TV
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Power Problem
Most likely the power supply is failing, or some other circuit that is causing a safety shutdown.
Without doing the proper tests and diagnistics, it is impossible to accurately speculate the exact fault.
Jerry G.
Jun 01, 2008 | Mitsubishi WS-65819 TV
No picture on my Philips HDTV
call a tech let them check your tv if no power it will be the power supply or related circuits.if you have sound then it could be video circuit module.as you said that it dont have pictures you did not mention anything about sound.good luck
Apr 23, 2007 | Philips 42PF9830A 42 in. LCD Television
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Zenith IQB64W10W 64" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
