Dell OptiPlex™ GX270 PC Desktop Logo
Anonymous Posted on Aug 07, 2011
NEED ethernet driver - Dell OptiPlex™ GX270 PC Desktop
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
5006
Points
26
To get the ethernet driver for the Dell OptiPlex GX270 please follow the following link to Dells website (http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R66787&SystemID=PLX_PNT_CEL_GX270&servicetag=&os=WW1&osl=en&deviceid=4159&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=0&libid=5&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=86705)
This is the Dell OptiPlex LOM (LAN On Motherboard) driver and should clear up any issues you are having with the ethernet port.
To install the driver you will need to Download it from the above link. Double click the downloaded file once it is complete. Follow the onscreen instructions.
Cheers, Garbanian
2answers
I loaded xp pro but my ethernet port is not active. Do I need to load ethernet drivers?
That means that the operating system doesn't have a database for your Ethernet device. You have to have the driver that came together with your PC and you should find the driver for your Ethernet device using that.
4helpful
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
1helpful
I need driver for dual ethernet and audio
You do not give the manufacturer of the motherboard; go to their website for a download of the needed drivers. You will need to know the board's model number.
2helpful
2answers
1helpful
4answers
Please, ethernet controller issues.
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
DRIVER
Hi there
Go here for the Ethernet driver you need, it is the "chipset" driver you need as the network controller (ethernet driver) is bundled with it.
I would recommend downloading all the drivers and backing them up just in case you need them in future.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=uk&product=3224052&lang=en
Good luck and thanks for using Fixya!!
Ethernet drivers
Windows XP Driver
Windows Vista Driver
These updates should sort out ethernet problems.
If these don't work or you have Wireless LAN, here is the Wireless LAN driver.
5helpful
5answers
Ethernet controller driver code 28
i need ethernet controller software for compaq(model NO: sr5060il)
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
