Kodak EASYSHARE Z1285 Digital Camera Logo
Posted on Aug 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any way to move a picture from internal memory to camera card using the camera functions?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Aug 07, 2011
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440585
Points
622693
Here's the page from the extended user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00731/urg00731c3s11.shtml
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
5helpful
3answers
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
After I shoot a picture the camera freezes up. I have to power off and up a couple of times to get it back to shoot mode. It does not store the image when it freezes up.
Can you power up the camera don't take a picture but move around the functions and view pictures on the LCD screen? If the camera does all the functions it's suppose to except hold a picture then I'd say the memory is at question. You might not have a memory card installed in the camera and it's working on the Internal Memory which is now full or not able to load another picture. If there is a memory card in the camera it might have the protection switch in the lock position which then would shift the picture storage to the internal memory. You need to check to see if there is a memory card in the camera if so make sure this card is in the unlock position. If the images are on the internal memory then you need to transfer the internal memory pictures to the memory card for download to the PC. Make sure the memory card is unlocked and formatted to the camera after you download the pictures to the PC
How to copy pictures from internal memory to memory cards
I don't know if there is a function to do this on your camera, but on the cameras I am familiar with, there is not.
However, if what you want to accomplish is to get your pictures from internal memory into your computer, there is a way. Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
1helpful
2answers
Internal memory is full on our M580 Can not toke pictures
I copied this from Kodak website Good Luck!
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
NOTE: You can also use a card reader to transfer picture files to a memory card. For more information on card readers and memory cards, go to KODAK Memory Cards
2answers
How do you save pictures from the camera to the memory card?
Press the MENU button. Select the Setup menu (the wrench and hammer icon). Select "Backup".
1helpful
4answers
I uploaded my pictures from my memory card onto the computer. When I put the card back into my camera, the camera won't read the memory card and it says the internal memory is full (12 pictures). How do...
If you indeed have the pictures on your computer (and are safely stored)... you might try selecting the format memory card function in the camera, to reformat the card, in case it was somehow corrupted while connected to the computer.
How do i transfer pic from the internal memory to the memory card
www.kodak.com/global/en/service
FOR MANUAL DOW[section title] Choosing Internal Memory or SD/MMCCard
The camera offers two options for storing pictures and videos:
Internal Memory —Store pictures and videos in 16 MB internal
memory.
SD/MMC Card —Store pictures and videos on a card. The number/length
of pictures/videos depends on the size of the card. Purchase accessories at
a
dealer of Kodak products or visit www.kodak.com/go/dx6490accessories. For
storage capacities, see page 114.
Managing Your Storage Location Setting (after inserting the card with power
OFF)
1 Turn on the camera.
2 In any still or video mode, press the Menu button.
3 Press to highlight Image Storage , then press the OK button.
4 Press to highlight an option, then press the OK button:
Auto (default)—the camera uses the card
if one is in the camera. If not, the camera
uses internal memory.
Internal Memory—the camera always
uses internal memory, even if a card is
installed.
5 Highlight Continue, then press the OK button again.
The setting remains until you change it and applies to all camera
functions.
6 Press the Menu button to exit the menu.
NLOAD.
4helpful
2answers
Internal memory to memory card
Generally, it's not possible to move images from internal memory to a memory card, which poses a problem because you can't connect that camera to your computer.
Most digital cameras keep the internal memory separate from the memory card. Not sure why, but they do.
It's unlikely that you'll be able to get those photos off, if the camera isn't recognized by the computer.
2answers
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
