SOURCE: Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
SOURCE: Upper Oven doesn't heat in bake or broil. Lower /Ctrl panel OK
check to see if both ovens are the same circuit if they are you have a internal problem with your upper oven internal circuits or damaged wirering contact a qualified service tecnitian
SOURCE: GE Double Oven JKP45BA, lower oven wont heat
If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
