During a Storm, the Power flickered at home once. I have this equipment connected to a Surge protector. In addition The power Company also installed a surge protector around the house so that all appliances and electronics are protected(FloridaPowerLight). Nothing was damaged during the storm around the house. After the incident the receiver works perfect with Any audio trough all HDMIs, including cable box, PS3, and USB connection in the front for IPOD also works perfect when it comes to audio. It will not pass video of any source to my TV. The Ipod has an interface that comes up when you connect the ipod, but it will not comeup either. The TV does not pickup the Video Signal. I currently have all my devices connected directly to the TV and it works perfect. IS this any easy fix? What could be wrong with the receiver that only passes audio trough? I left the receiver unplugged for 1 week and it did not help.
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
I hate to be the bearer of bad news, but there is no reset on the phone system, and it's a near certainty that a power surge during the storm "fried" the sensitive circuitry in your phone. The same thing happened to me a couple of years ago and I ended up replacing my phone system. A corded phone in the house at the same time lost its ringer during our storm. To this day it still works fine, but will not ring. While you cannot save your present equipment, it's possible to protect your replacement by installing a phone line surge protector (available at just about any store that sells phones or computers) and a whole house surge protector that you install at the main outside breaker box (you'll need to search the web for that one. Look for a SYCOM surge protector).
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV. * First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Do you know if your Wii is connected to a surge protector? You can get power surges at many times especially when the power goes out, or even comes back during a storm.
If you do have a surge protector connected you may want to see if your fuse needs to be reset. If not I don't think that the Wii's manufacture's would cover surge damage.
Sorry I didn't have happier news.
Jon
Go Ahead. Use Us.
