My side-by-side GE refrigerator, Model # PS123SGRC, is malfunctioning and '"HRS" is blinking on the control panel. In addition, some of the button lights on the water dispener area are flickering. The refrigerator is not cooling, the panel that usually displays the temperature is no longer doing so. Any insight is greatly appreciated.
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
If it is the model I think you have just unplug abot thirty minutes and plug back in and the control board will reset. If that does not work the send your model number and I will help you, Thank You Sea Breeze
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Your refrigerator has a control board on the back behind a metal panel. Unplug and look at both sides to see if you see burn marks or loose solder. Go to this site and place model PS123NCRBV into the model search feature.That will take you to 13 similar models. The board on back is my first concern and the control inside will need to be looked at also if you find no problems on the back. The control board number is WR55X10656 let me know what you find, Thanks, Sea Breeze
Unplug refrigerator and remove panel on back to expose the control board. Look for burns or smell of burned board. Look at both sides and let me know if you see any problem, Thanks, Sea Breeze
there is a board in the back right side behind a panel embedded in the back of the unit just above the back cover. it is a Part # WR55x10552 this is most likely your problem it controls all functions of the unit
Here is a link that will help give you a step by step process of elimination, click below and insure you have the correct model numbers as you move through the process, Thanks Sea Breeze http://www.repairclinic.com/SmartSearch/smartsearch.aspx
