Cell Phones Logo
Posted on Aug 07, 2011
My motorola C601A did not function..only displaying BASE 1 on monitor..cannot call,cannot accept call..cannot acces the setup button..
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 04, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4993
Points
0
I got the same issue as above. You just need to register the base again by the step below:
1. Press the button on your base (like a speaker icon) without release it until you hear beep sound.
2. Press 'OK' to enter the MENU on your handset
3. Go to REGISTER
4. Then go to REG BASE
5. Press '1'. The screen will now showing SEARCHING BASE1
6. Wait a while then it will back to normal.
7. Put back your handset to the base and now the screen should show HANDSET 1.
Your cordless phone shall be ready to be used as normal again.
  • Anonymous Mar 04, 2013
    Sorry that I missed out the pin . The pin shall be '0000' after the reg base button has been hit.
Can't turn on the answering function on my l701m phone. Bob
There is a forum dedicated to phones and tablets - perhaps posting your query there would help you obtain the information you require,
Dec 23, 2016 • Cameras
1helpful
2answers
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
5helpful
How to reset low tire pressure light
How to reset low tire pressure monitor, the reset is in radio controls. 1. Turn the ignition to ACC or ON and turn the radio off.
2. Press and hold the TUNE DISP button on the radio for at least five seconds until SETTINGS is displayed.
3. Press SEE PSCAN up or down arrow to scroll through the main menue.
4. Scroll until the TIRE MON appears on the display.
5. Press the 1 PREV or 2 NEXT button to enter the submenu. RESET will be displayed.
6. Press the TUNE DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7. Once the monitor has been reset, scroll until the EXIT appears on the display.
8. Press the TUNE DISP button to exit programming. A chime will be heard to verify exit.
Hope helps (remember to rate this).
3helpful
My motorola d10 phones will not register to the base.. i have two units and i wanted to use the intercom feature but cannot get either unit to show any signs of registering to the base.
Hi, I may be late at posting a reply but I had the same problem and I'm an IT Practitioner - So Motorola don't seem to like making things easy or even giving instructions - I tired out Google and eventually came across the result myself:
1. Go To Advance Settings
2. Then Go To Registration
3. Then Go To Search Base
4. And Keep Hold Of The Page Button On The Main Unit
( You May Have To Do This Several Times)
5. The Screen A Should Display PIN
6. Enter The PIN Which Is 0000 (Unless Changed)
7. REGISTRATION COMPLETE!!!!
Also I had problems with the intercom feature - when I attempted to intercom another handset - It wouldn't ring but this was fixed by turning the room monitor (Baby Monitor) off.
Best Wishes PINDY92
1helpful
2answers
I want to change my TH6110D1013 honeywell thermostat to celsius . how do i do it?
You need to go into the setup mode to change it. Push and hold the i button along with the increase and decrease buttons. All the segments on the display will appear for about three seconds, then setup number will appear to the left and factory setting to the right. Change the setup number by pressing the (i) button until you get to 14. This is the degree temp. display, factory setting is 00. Use the arrow up key to change to 01 (celsius).To exit setup, push and hold the(i) key until the display returns to normal.
1helpful
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
2helpful
3answers
Users Manual on how to use
Motorola Walkie Talkie Code and Channel Setting
  1. Push and hold On/Off button. It will tell you Code & Channel
Note: You are now in the change mode
  1. Change Code - Push the talk button till handsets match Code then push monitor button to accept
Note: You are still in the change mode so you can change Channel
  1. Change Channel - Push the talk button till handsets match channel then push monitor button to accept
  2. To check repeat step 1 then push on/off button
2helpful
UltraRacer playstation 2 controller programming
Here's the instructions on how to relocate buttons:
1. To assign one button (i.e. "R") to perform another buttom function (i.e.
"Z"): Press and hold the SET button for about 1 second to enter the
"FUNCTION SETUP MODE", the FUNCTION SETUP LED will illuminate and two beeps
will be heard.
2. Press the button (i.e. "R") you would like to reassign one time, the
FUNCTION SETUP LED will blink once and a single beep will be heard.
3. Press the new, desired function (i.e. "Z") one tim, the NORMAL LED
indicator will illuminate instead of the FUNCTION SETUP LED. Two beeps will
be heard. The setting process is now complete.
The UltraRacer will only return to its default setting when the buttons "A",
"L", and "R" are pressed at the same time BEFORE you turn on the console's
power. After about two seconds, the UltraRacer will generate three beeps to
acknowledge reset button configuration is set. To reset a particular button,
first press the SET button, then press the relocated button twice and then
press the SET button once more until the LED light goes off. THe button's
original function is used as a default button for further relocation.
These instructions were told to me bay a company selling these controls on AMAZON. I have been trying to reprogram mine and cant figure out where the "R" button is.
1helpful
2answers
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Display locked after trying to sync
The Ming is a very new product, and is not yet released in the USA. My suggestion is to contact Motorola directly. They are very good about warranty and will most likely overnight you a replacement. Best regards, torgo
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
